Tool Talk Discussion Forum
Generator Help
Big Mike(Mi.)
10-22-2005 13:42:36
Can anyone give some troubleshooting advice for a Generac HA1850 generator. It runs great but does not have output.I have a schematic but still am not sure where to start.
Thanks!
Mike.
ronnie269
10-26-2005 18:45:00
 Re: Generator Help in reply to Big Mike(Mi.), 10-22-2005 13:42:36
I finaly got it putting out the right volts and Hz.
Thanks to everyone: Ron
Big Mike(Mi.)
10-25-2005 18:38:19
Well tried to flash the generator with an electric drill and still nothin so I will give it to the local small engine guy for parts.
Thanks for the replys.
Mike.
Earl -IL
10-25-2005 19:49:01
 Re: Generator Help in reply to Big Mike(Mi.), 10-25-2005 18:38:19
The drill method has always worked for me .The key is TO SPIN THE DRILL IN THE OPPOSITE DIRECTION YOU HAVE IT SWITCHED TO. IF NO SWITCH SPIN THE DRILL BACKWARD .IF A SWITCH ,SWITCH IT TO FORWARD AND SPIN IN BACKWARD. Earl
Hermit
10-22-2005 18:49:40
 Flashing The Field in reply to Big Mike(Mi.), 10-22-2005 13:42:36
There were a couple of references on the internet saying that the stators went bad on Generac generators. Here are 3 different methods of flashing the field. I don't know if they will work or not, it's just info out on the internet. So, as with anything on the internet, take them with a grain of salt and a degree of caution.
Link
Link
http://www.endtimesreport.com/dead_gen.html
Bob
10-22-2005 18:26:12
Start by "flashing" the fields. That is the correct term, with an AC generator such as this.
"Polarizing" generally refers to restoring the residual magnetism in a DC generator, often on an antique car or tractor.
I simple was to "flash the fields" is detailed at the link below:
Ronnie269
10-22-2005 18:41:25
 Re: Generator Help in reply to Bob, 10-22-2005 18:26:12
Bob, thanks so much, I"ll try her the first thing in the morning
Bob
10-22-2005 18:29:05
Need to proofread better, I guess!
"I simple was to "flash the fields" is detailed at the link below:"
SHOULD read:
" A simple way to "flash the fields" is detailed at the link below:"
johnny t
10-22-2005 17:47:13
i'm with mac. if it hasn't been ran in a long time it will need polarizing like he said. ask some small engine shop how to do it. it something real simple like arching two contacts with a paper clip the best i remember. keep it cranked regual and plug something into it to keep it polarized.
Hermit
10-22-2005 17:36:55
From the manual:
1. Circuit breaker open
2. Poor connection or defective cord set
3. Connected device is bad
4. Fault in generator
http://www.generac-portables.com/data/pdf_files/gen/9855_1en1w.pdf
MAC,IL
10-22-2005 14:56:34
Could be it just needs polorizing.
