How to remove paint?
Andrew
01-31-2001 20:05:44
How can I remove two coats of tractor paint and one coat of primer off my garden tractor? It is less that a year old. ( don't ask me how it got on it). I would like to remove all of the paint since I am starting to restore it. thanks!
Andrew
Mike
01-25-2003 02:20:23
 Re: How to remove paint? in reply to Andrew, 01-31-2001 20:05:44
I dont think these guys read right. DONT USE PAINT REMOVER!!!!! !!!!! !!! He spilled paint on it guys and wants just the spill cleaned off. iF ITS NOT TO THICK JUST USE BUG AND TAR REMOVER. IT ITS THICK TRY PEELING IT OFF WHILE HEATING IT WITH A HAIR DRYER.
Tom
02-02-2001 05:42:39
Go down to an auto parts store that handles paint. Get "Aircraft Paint Remover". This will remove any paint. I have used it in restoring cars for 20 years, there is no chemical better than this for what you want to use it. Be careful, powerful stuff.
Andrew
02-01-2001 19:32:15
The paint is a year old :-) I will try some of this stuff out and let you guys know what happens, More suggestions are welcome!
Andrew
PAUL8N
02-01-2001 19:14:40
WHY WOULD YOU RESTORE A TRACTOR THAT IS ONLY A YEAR OLD????? ??? :-)
Bud
02-01-2001 17:23:31
Here is a receipe that was put forth on the 8N board. I use it and it works absolutely great. Is cheap as heck also, which is a bonus. I have only used this on metal, so I can't say for other surfaces. Mix a little water, lye, and a tiny amount of cornstarch to make a gel just like the commercial stuff. You can add a little more lye if not strong enough. I can mix either a cup full of stripper at a time, or more, if the job warrants it. It helps if the water is warm and I find that it mixes easier if I mix the water and cornstarch first to make the gel and then add the lye last. USE EYE & HAND PROTECTION !!!!
(You can get the can of lye at the grocery store in the drain cleaner department.)
Jerry
02-02-2001 05:07:24
 Re: Re: How to remove paint? in reply to Bud, 02-01-2001 17:23:31
Don't use lye on aluminum parts...lye is a very strong base (opposite of acid), and will strongly react, i.e., dissolve, aluminum.
Bart
02-01-2001 13:44:42
If you buy paint stripper, buy Old Dad;s type. Comes with a spray bottle and is the best I've ever seen. About 19.00 a gal. at Sears, etc.
walt
02-01-2001 06:49:14
Down to bare metal? Use Easy Off oven cleaner, heavy duty type.
bob
02-01-2001 15:20:29
 Re: Re: How to remove paint? in reply to walt, 02-01-2001 06:49:14
how do these products work on fiberglass?
D W
02-02-2001 10:09:33
 Re: Re: Re: How to remove paint? in reply to bob, 02-01-2001 15:20:29
This is for people who find them selves stripping a lot of small parts. Use a 55 gal steel drum, water and lots of lie. (I do'nt remember the ratio). You need a source of heat. Gas or even a wood fire. Heat to low boil or simmer. Hang parts with wire. I have left parts over night. they will come out clean as a whistle. Do'nt do this to any white metal. You wont have anything left. You can put a lid on the drum when your done,and use it again later.
D W
02-02-2001 10:20:49
 Re: Re: Re: Re: How to remove paint? in reply to D W, 02-02-2001 10:09:33
I forgot to mention caution and common sense. Goggles or face shield and water handy to rinse any possible splashes or spills on your self.
