Tool Talk Discussion Forum
generator
ronnie269
10-22-2005 05:13:18
I have a subaru ( diesel) generator model number SDG2200S, I"m haveing to run it at twice the normal RPM"S to get 120 volts, sixty cycles , can anyone tell me what could cause this? Also would like to get a tech manual on this Gen>
Thanks for your help
[email protected]
T_Bone
10-22-2005 09:24:30
 Re: generator in reply to ronnie269, 10-22-2005 05:13:18
Hi Ronnie,
Without more info, either you have a 2pole generator on a 1800rpm engine or you have a 4pole generator that has two poles wired wrong or missing 2 poles.
What brand of diesel engine allows you to safely double the RPM? two stroke?
T_Bone
kidbob
10-22-2005 07:36:27
I don't understand. If it is a 120V 60H generator then there is only one speed that will deliver 60H, any other speed will be more or less Hertz, the voltage is controled by a regulaator.
ronnie269
10-26-2005 18:42:47
 Re: generator in reply to kidbob, 10-22-2005 07:36:27
Thanks everyone, I got her going! Not sure what the problem was, it started working just like it quit, instantly!
thanks again Ron
