Tool Talk Discussion Forum
Siphon gizmo??
Jonny
10-21-2005 08:05:01
I saw a guy siphoning fuel with about a 3 foot, 1/2 inch clear plastic hose with a ball check valve in one end. All he had to do was put the check valve end in the fuel can and move it up and down a couple of times and the fuel started flowing. He said he got the device at a hardware store in Texas a few years ago and when he went back for another, they said they couldn't get them anymore. Anyone know of a source for this great tool? Thanks, Jon
pdi man
10-22-2005 11:28:53
 Re: Siphon gizmo?? in reply to Jonny, 10-21-2005 08:05:01
gotm mine at pep boys. 13 bucks.
Hobo,NC
10-21-2005 16:00:06
I use a boat tank primer blub you kin find'em bout enny weres
Dick2
10-21-2005 14:46:29
Our neighbor would make a mad dash to my tractor and siphon out gas when I went over the hill for lunch. One day I waited 5 minutes and drove back over the hill and caught him. I only said one thing to him: "Just remember that I can pick off somebody a mile away with that hot rifle my brother has (he's a gunsmith)." Never missed any more gas after that!
MPND
10-21-2005 12:57:19
Keep those things away from my neighbors. I already got sucked dry once this fall. If they had those fancy things i would have to sell my tractors and buy horses.
williamf
10-21-2005 22:17:40
 Re: Siphon gizmo?? in reply to MPND, 10-21-2005 12:57:19
What would they get if they used one on a horse?
Wm
Deere in Ar.
10-21-2005 11:47:46
You can do the same thing with your thumb on the end of a siphon hose. Just push hose in to can or tank,place thumb on end of hose as you pull up quickly,remove thumb on downstroke,place thumb on hose for upstroke. About 3or4 times will do,then hold thumb on till you lower that end of hose.
MAC,IL
10-21-2005 11:43:16
I picked up a gizzmo a few years ago. Had a plastic thingy you squeezws and it started the siphoning motion. When you were thru, you opened a small valve on top of the bulb. Seems I may picked it up at the local TSC store. Works great. Intake is just right for a 5 gal can. I guess if you needed more length on both ends you could adapt a plastic hose to it.
wyokid
10-21-2005 10:47:41
Same principle as starting a siphon tube off an irrigation ditch.
Johnski
10-21-2005 10:19:23
I just saw a bunch of them hanging up in Lowes. I think they were about 7 beans and change. HTH
Bguy
10-21-2005 10:00:38
You mean something like this?
Mike M
10-21-2005 11:07:10
 Re: Siphon gizmo?? in reply to Bguy, 10-21-2005 10:00:38
That's the one I have and they really do work great ! Shop around you should be able to find them cheaper than that site.
Slowpoke
10-26-2005 01:09:15
 Re: Siphon gizmo?? in reply to Mike M, 10-21-2005 11:07:10
Yeah, they do work great. As long as the empty container is lower than the filled container. The hood on my Case is about 5' high...to high to hold the gas can and pour without a ladder. So now I have to lift the 5 gal can up on the hood and stand on the front axle to use the siphon hose. Well, it does eliminate the funnel.
Name with held
10-21-2005 09:47:34
Isn't that what they call a Texas credit card?
Not an Okie
10-21-2005 18:17:21
 Re: Siphon gizmo?? in reply to Name with held, 10-21-2005 09:47:34
I thought it was an "Oklahoma Credit Card".
Mike M
10-21-2005 09:30:28
I first saw those when I worked at a heavy truck dealership a few years ago. I got one and they do work very good. These were called Super Siphon. Siphons should be makeing a big come back since the price of fuel is so high. LOL
RustyFarmall
10-21-2005 08:24:08
A similar device used to be furnished with kerosene heaters to allow you to siphon the fuel from the 5 gallon can into the tank on the heater without making a mess. Might be able to find one at a store that sells kerosene heaters.
