Tool Talk Discussion Forum
Duct cleaning...
Dick2
10-21-2005 04:50:17
Has anyone cleaned out their own ducts? Or had ducts cleaned professionally? Just wondering what chemicals would be safe to use?
Leland
10-21-2005 19:40:00
 Re: Duct cleaning... in reply to Dick2, 10-21-2005 04:50:17
We hired a company and had ours cleaned and it was the best money spent ,they came and done there job and we were hardly sick that winter due to all the mold and dirt was removed . Before cleaning we where sick all the time , The guys that think it's a scam don't know what they are talking about .
David - OR
10-22-2005 09:16:12
 Re: Duct cleaning... in reply to Leland, 10-21-2005 19:40:00
The EPA (your tax dollars at work) has a full discussion about the pros and cons of duct cleaning at the website below. One quote from the article:
"If no one in your household suffers from allergies or unexplained symptoms or illnesses and if, after a visual inspection of the inside of the ducts, you see no indication that your air ducts are contaminated with large deposits of dust or mold (no musty odor or visible mold growth), having your air ducts cleaned is probably unnecessary."
And also this:
"However, a light amount of household dust in your air ducts is normal. Duct cleaning is not considered to be a necessary part of yearly maintenance of your heating and cooling system."
Read the reference for yourself, and make your own decision on duct cleaning. It's your money. The article also provides useful information to help you evaluate whether the folks performing the work are actually taking the appropriate actions.
As for me, I stand by my opinion that most duct cleaning is not needed, and remain unpersuaded of its universal goodness by isolated anecdotal reports. (Homeopathic medicine has similar vigorous advocates). If you do not have air conditioning and do not have an add-on humidifier, there should be no moisture in the ductwork to support the growth of mold.
IAQ....John,PA
10-22-2005 04:33:00
IOQ stands for "indoor-air quality".
Hospitals, schools, and most public buildings, nowadays, must have their duct work cleaned for state inspecions.
You are wise to have had your system cleaned in your residence.
GOOD FOR YOU!
Most do-it-yourselfers can really screw things up with their FIBERGLASS ductwork. The ducts will start eroding and have fiberglass floating around their house for years. That ain't good.
John,PA
PS: Pantyhose...John, PA
10-22-2005 09:50:49
 Re: Duct cleaning... in reply to IAQ....John,PA, 10-22-2005 04:33:00
One simple test will determine if'n you might consider cleaning the ducts:
Cover a spare pressure diffuser, floor or ceiling in your residence with a piece of clean panty hose. After 2 weeks of normal operations, see what collects.
I insist that this be done after the house is newely finished before I consider the house safe for HUMANS, and certify as such!
Most just wait until the ceiling needs repainted (dirty), especially in SUPERMARKETS
Their computers are the first indication for duct cleaning. The cooling fans pick up the debris and eventually the computers will burn-out.
Vern-MI
10-21-2005 10:35:54
I cleaned mine by dropping sections of the main hot and cold runners and using several sections of shop vac rigid extensions twisted together. I could reach down the ducts about 12 feet and clean the bottom of the duct with the brush pickup tool at the end of the extension. There wasn't any dirt clinging to the side walls or top of the duct. All of the dirt was lying on the bottom of the duct and it was primarily composed of sand which had collected into ridges on the bottom of the duct like the sand ridges at the bottom of a lake. The ducts come apart rather easily by sliding out the crimped metal connectors the intersections of the metal ductwork.
David - OR
10-21-2005 09:41:28
I consider "duct cleaning" to be an unnecessary action bordering on a scam, very similar to those advertisements for agents to pour down the toilet to supposedly improve the operation of your septic tank.
The air velocity in a properly designed forced air system is insufficient to move anything but the smallest particles of dust, skin, and hair. And most of those will be caught by your furnace filter before the air is recirculated to the supply ducts. The ducts are probably quite clean.
Most/all of the dirt that you see at the supply registers falls in there by gravity. Get your shop vac and sweep it out if it bothers you.
One possible exception: if this is a new (to you) house, and the previous occupants were heavy smokers, or had pets, AND you or your family is allergic to those things, AND you do not yourself smoke or have pets, then it might be worthwhile, one time only, to clean the ducts. While I still think the shop vac is good enough, a specialist would have the special tools to deal with flex duct vs. metal vs. ductboard.
Chris (WA)
10-21-2005 05:21:02
Dick, What goes thru the ducts? We have a gadget for cleaning ducts that handle lint. Looks like a drain snake with a weed whipper on the end. Hook a vac on the inlet of the duct and run that thru and all the lint comes out! Run the dryer with a bag on the exhaust for a min or two and you are in good shape. If you are talking about fresh air ducting like furnace ducts I would shy away from any chemicals due to the chances of residuals in the duct after cleaning. That is one I would leave to the pros. I suspect they have special tools like our duct snake or a chimney brush type thing to clean the square ducts.
Lefty
10-21-2005 07:10:56
 Re: Duct cleaning... in reply to Chris (WA), 10-21-2005 05:21:02
You could avoid chemicals etc by oiling up an irate raccoon and runnin him thru the pipes.
Stan in Oly, WA
10-21-2005 17:56:30
 Re: Duct cleaning... in reply to Lefty, 10-21-2005 07:10:56
The raccoon wouldn't have to be irate when it started.
