Tool Talk Discussion Forum
Water in Gas
smark
10-19-2005 12:51:34
I suspect that there may be water in the gas I have in my Tractor. Is there any way to tell for sure? Does the Water float on top of the gas or is water heavier than Gasoline? Or does the Water and Gas just Combine?
1945 A
10-20-2005 11:56:53
 Re: Water in Gas in reply to smark, 10-19-2005 12:51:34
Like the others have said, water and gas will not mix---water will settle (actually, it sinks pretty fast:) when mixed with gas).
My experience with the situation of water in gas has been, that either the engine won't start, or will suddenly back fire or sputter. You didn't say why you suspected water in gas.
Quick test, that doesn't cost any more than time, is drain the fuel bowl on your carburetor onto some kind of non-absorbent surface if there's water present, it will look like drops of oil in the mix--beads of water,in other words.
If there's water, you'll have to determine how it got there---gas can, leaks, etc...
Good Luck!
Wisconsin Bill
10-19-2005 20:09:56
Water sits on bottom-should see line in sediment bowl where water/gas meet, or if all water, then no line. Check by smelling/feel etc. my dad's old trick still works.. add methanol [Heet in yellow bottle] to get ice to melt and it mixes with water & sits on bottom of tank , taking all water out of gasoline.(not good, but ice melts) If above freezing, add isopropyl alcohol [Heet in white bottle]; this causes water to join with isopropyl and then these disperse throughout the gasoline and will actually burn through the carburator - not as good as 100% gas, though. This works with just small amounts of water. Large water amounts, drain tank first, then isopropyl into gas tank. Then fix water entry problem.
Jay (ND)
10-19-2005 15:40:40
If you have a good clear gas tank that you can see into well, the water at the bottom will look like cooking oil in a glass of water would. You can go get yourself some water finding paste and that will tell you. The water should be in the sediment bowl, so you should be able to see a line there - unless it's full of water. Remove the bowl, open the valve and find out. Don't be afraid to use the sniff and taste tests.
RustyFarmall
10-19-2005 14:36:11
Water always goes to the bottom if allowed to sit.
Leland
10-19-2005 18:43:12
 Re: Water in Gas in reply to RustyFarmall, 10-19-2005 14:36:11
Don't worry watch the little glass bowl on the bottom of tank it will let you know .
BobMo
10-20-2005 05:15:47
 Re: Water in Gas in reply to Leland, 10-19-2005 18:43:12
Don't always work since many units don't have "little glass bowl"..... ....
