Tool Talk Discussion Forum
420 tracked cluch ajustment
alan james adam
10-18-2005 06:56:12
can you tell me how to ajust the steering cluches on our 420 or do they need to be replaced and if so how big a job is it thanks alan
BobMo
10-19-2005 05:05:14
 Re: 420 tracked cluch ajustment in reply to alan james adamse, 10-18-2005 06:56:12
The manual gives the correct step by step procedure.
Bernie in MA
10-18-2005 14:08:26
I've had a 420C since 1959 when I bought it new. Remove the barrel-bung cover on the front of the final drive housing, just behind your foot. Take off the square cover on top and shine a flashlight down in there. You'll see the head of a bolt that tightens over a slot. You might have to turn the clutch a little to see it. It holds the collar that the throwout bearing is on.
If everything isn't rusted up you should be able to loosen the bolt and by pullimg the steering lever back carefully, slide the throwout bearing away from the clutch fingers. Don't go too far; it might not be easy to move it back. If it doesn't move at all or the bolt breaks off you'll have to pull the final drive. Also it could already be adjusted to the end of the slot. HTH
alan james adams
10-19-2005 10:11:59
 Re: 420 tracked cluch ajustment in reply to Bernie in MA, 10-18-2005 14:08:26
ajustment thsnkd i will try to ajust the cluch. hoe big a job is it to install new cluches?
alan
Bernie in MA
10-21-2005 09:41:11
 Re: 420 tracked cluch ajustment in reply to alan james adams, 10-19-2005 10:11:59
You have take the track and final drive off in order to get to the clutch. Replacing the discs is the easy part. John Deere still sells the shop manual, about $60.
