Tool Talk Discussion Forum
Shop Heat
Jerry Cent. Mi.
10-14-2005 15:27:33
Thanks for all the good shop heating suggestions on my previous post. I decided to go for a 45,000 btu Mister Heater verses the Modine I was looking at. Modine uses a stainless steel vent pipe and the Mister Heater uses 26 ga. steel vent pipes. Should I use stainless on the Mister Heater also to play it safe?
Mike M
10-16-2005 17:24:58
 Re: Shop Heat in reply to Jerry Cent. Mi., 10-14-2005 15:27:33
When I got my Mr. Heater the vent kits were on eternal back order. Cold was here I had to get it going. The instructions were kinda confusing.I had some instructions from a similar model from another company. Mr. heater said to slope it up other co. said slope it down ? Down made more sense to me as I wanted the moisture/water to run away from the heater so it didn't corrode it and drip on the floor. I didn't need to go very far so I ended up buying a section of 3" OD aluminized exhaust tubing 8 feet maybe ? had it expanded just a tad to fit the adapter. mounted the heater,cut a hole in the wall that offered a little slope down and out. I had a bright idea to try a exhaust flapper mounted on the horz. pipe cut and modified the weight but this idea was NO GOOD as it would not work right. Heater blower doesn't have much force so it needs to free flow out. I bought a 3" flue vent cap and used it to keep the birds and critters out. These really do put out some water but here in northern Ohio I had none freeze on my pipe just a little ice pile on the ground.
