Tool Talk Discussion Forum
Truck capacity
JimDR
10-12-2005 09:05:50
I have an 89 Toyota pickup that has one overload leaf in the springs. Could I carry 1000lbs + my wife and I @ 290lbs?
riverbend
10-13-2005 20:00:19
 Re: Truck capacity in reply to JimDR, 10-12-2005 09:05:50
Don't load your truck beyond the point where the springs are straight. Anything up to that point is fine if you use a little common sense ( and don't overload your tires).
Sam#3
10-14-2005 06:09:32
 Re: Truck capacity in reply to riverbend, 10-13-2005 20:00:19
. . . Or your wheel bearings.
720Deere
10-13-2005 12:30:18
With a helper spring, I would haul 1,000 pounds in my 91 extended cab V6 just about anywhere. I have hauled a few hundred pounds more than that, but you need to go easy. Without the extended cab I think you can get more of the load on the front axle as well. I usually try to load as much of the weight as I can ahead of the rear axle. Anything behind the axle is leveraging the load and putting more weight on the rear axle.
Bret4207
10-13-2005 09:11:18
Absolutely. Toyota is built he77 for stout. I own 2, a 90 and a 91, and use them for farm work. They'll do anything any other half ton truck will and get you better milage too. Not trying to start a brand war, but the darn little trucks are real troopers.
cj3b_jeep
10-13-2005 08:55:35
Jim, just a few weeks ago I had more than 2,200 pounds of 4/11 fill on my '90 toyota 1/2 ton. It has a set of 1 ton springs and is the extended cab v-6 model. I would not drive with that much weight for very long distances, but it will handle it. I've got 197,000 miles on mine.
Mark - IN.
10-12-2005 17:57:15
It depends. Up hill, or down hill. LOL. Just jokin'. What's it rated for, as others have asked?
My brother has one about that year. Dangdest thing I ever saw. His is a 1-ton Toyota. Is a little pickup with a 6' bed, and is a 1-ton by gosh. He uses it on his property to haul firewood and stuff around. Good thing he only uses it on his property. He's legally blind and doesn't have a drivers license (good thing there too). But, he manages to do things when no one's around to help him.
Mark
Leland
10-12-2005 17:28:26
It won't hurt a thing I had a mazda B2600 and hauled a 200 gal water tank all the time . And even at the transfer station I pulled in there one day to get rid of dry wall and tipped the scales at 6800#s ,just watch the news and see how many taliban fighters and weapons you can fit into a mini truck .
dr.sportster
10-12-2005 15:30:22
Ask a mason.Ever see how they overload the small trucks? Never buy a used truck from a mason those springs are hurting.
02
10-12-2005 13:04:54
I have carried much more on my '86 Toyota.Keep an eye on the rear axle housing where the rubber bumpers hit the axles when the load is too big.I have loaded far beyond this point but didn't have to go far or fast.If you can place most of your load ahead of the rear axle you will have no problem.
Tim B from MA
10-12-2005 09:15:55
the tag on your driver's door should give the recommended Gross Vehicle Weight; you will have to know how much the truck weights; the diff between the GVW and the truck weight is what the manufacturer thought it was safe to carry. Keep in mind that now that the truck is older, it may not be as sound as it once was in this respect.
That being said, if this is one of those small Toyota, single rear-wheel pick-ups, a 1,290 pounds is probably too much.
How much of that 290 pounds is your wife, maybe you could leave her at home :)
old
10-12-2005 09:11:50
Probably, but it might be a little more then you should. There should be a tag inside one of the dorrs that would tell you GVW and thats what you can haul.
504
10-12-2005 20:07:59
 Re: Truck capacity in reply to old, 10-12-2005 09:11:50
Jim, If I had any pants on I would go outside and look at the tag on mine(89 2X4 V-6)But I pull a 20ft flat trailer and a 21ft camper. I have replaced the top leaf and added another. 25mpg and it drops to 17mpg with a trailer. After I put the first load of rock on the trailer and crossed the scale at 11,800lb i hooked up the brakes and raised the plates from 6000# to 12000#,best truck I ever had but it is getting a little weak at 202,000.
jfp
10-13-2005 13:10:58
 Re: Truck capacity in reply to 504, 10-12-2005 20:07:59
I got to give credit when credit is due they are tough little trucks and I would have one if I could just fit in it. I wish the cabs were bigger. I do like them for dependability.
