Tool Talk Discussion Forum
Treating Slightly Dry Rotted Tires
Glenn F.
10-09-2005 06:18:11
I haved a set of tires which are slightly dry rotted. Does anyone know of a product which effectively treats this condition? I have not checked with Miller Tire yet. Thanks, Glenn F.
MAC,IL
10-10-2005 10:21:47
 Re: Treating Slightly Dry Rotted Tires in reply to Glenn F., 10-09-2005 06:18:11
I had a couple tires like that, ended up having to replace them in short order.
2x4
10-09-2005 22:18:38
an effective treatment for your tires is kerosene, a match & a brushpile. Dry-rotted tires can kill you.
Slowpoke
10-09-2005 11:17:29
There was a show on the History Channel the other day about chemicals or something like that. It had a segment about Armorall research where two small tire sections were exposed to sunlight and ozone. One was treated and one left untreated. The treated one looked new, the untreated one was severly weather cracked. I think it's too late for your tires, but you could try.
msb
10-09-2005 20:09:01
 Re: Treating Slightly Dry Rotted Tires in reply to Slowpoke, 10-09-2005 11:17:29
Ordinaly silicone spray will do the same thing as Armor All is mostly silicone.Silicone protects the rubber from ozone which causes rubber to deteriorate.
Tom Fletcher
10-09-2005 09:01:37
Being "slightly dry rotted" is kind of like being "slightly pregnant" isn't it??
lucasss
10-09-2005 07:38:16
i think once you have that condition you cant reverse it. but tire supply places have a spray on that keeps rubber from drying out.i use it on suspension air bags and chassis bushings, but our tires wear out the tread before they start to rot, lucas
