Tool Talk Discussion Forum
Parts for REX Wheeler pipe threader, 6790
Redd
10-07-2005 17:31:31
I have a nice REX power pipe threader model 6790, 1/2" thru 4" that I would like to find parts for. The hand wheel on the left that tightens like a chuck to provide a steady rest for the pipe while its turning is broken. Its cast aluminum and looks like pie pieces now. The welder is afraid it will be too warped when he gets done. Boy that thing sure snapped when it tipped over. It still works good and I'd like to sell it. I have all the dies and enough of the thread inserts to do all the pipe and bolt threads (probably 75 lbs of them).
Dusty
10-08-2005 17:53:01
 Re: Parts for REX Wheeler pipe threader, 6790 in reply to Redd, 10-07-2005 17:31:31
Perhaps if you cleaned the parts with alcohol and used epoxy for glue you could save the old hand wheel.
Dusty
Steve Andersen
10-08-2005 05:48:55
Try this:
Wheeler Manufacturing
A Division of Rex International USA, Inc.
P.O. Box 688
3744 Jefferson Road
Ashtabula, OH 44005
Ph: 440-998-2788
Fax: 440-992-2925
Toll Free: 1-800-321-7950
www.wheelerrex.com
email Wheeler-Rex
Slowpoke
10-08-2005 02:13:24
Can you adapt a standard hand wheel as a replacement?
MAC,IL
10-07-2005 18:25:27
That co is still in business. I am not familiar with it or age. however you Might do a search for that company and see if you can find an 800 number to call. Looks to me like you could possibly fabricate a wheel. Perhaps make a round plate that would fit the existing wheel and just bolt it together.
Redd
10-08-2005 05:38:04
 Re: Parts for REX Wheeler pipe threader, 6790 in reply to MAC,IL, 10-07-2005 18:25:27
Thanks, The wheel is quite complicated because it turns against a spiral on the machine which in turn closes the three "jaws" against the pipe you are turning. Similar to a quick change chuck on a metal lathe. The only thing I can think of is to cut a round piece sheet metal and drill and tap the aluminum pieces and put short screws in it. Similar to how you would patch an engine block hole.
Slowpoke
10-09-2005 10:33:51
 Re: Parts for REX Wheeler pipe threader, 6790 in reply to Redd, 10-08-2005 05:38:04
If you can post a picture, we might have better ideas.
