Tool Talk Discussion Forum
hydraulic cylinder rebuild
JJP
10-07-2005 17:23:17
I have an International single acting hydraulic cylinder that I would like to replace the seals and o-rings on, but I can't get the cap off!
There is a key hole in the cap and I can see what looks like a piston ring, but I don't know what to do.
Any ideas?
the tractor vet
10-08-2005 10:43:13
 Re: hydraulic cylinder rebuild in reply to JJP, 10-07-2005 17:23:17
They have a square cut pice of wire with a hook on one end to roll it in and out with there is two flat spots on the end of the cap to put a wrench on to turn the cap . Clean out the square hole and turn easy to fine the end if it stops turning then go back the other way or you will shear of the tang then it gets fun when ya find the end i use a pick and a small screwdrive and lift it up and turn it backwards and it will (should ) roll out and it goes back in the same way the new wire comes with the rebuild kit.
NC Wayne
10-07-2005 21:29:16
If I'm understanding what your describing correctly your cylinder has a retaining ring in a grove between the head and the barrel of the cylinder. If that's the case then head of the cylinder should have at least two holes in order to use a pin spanner to turn it. First take a small screwdriver or a good heavy scribe and see if you can get the end of the retaining ring to come up through the slot. Sometimes you can look at the slot and it'll have one side more tapered than the other, if that's the case the head will turn in the direction of the taper to get the ring out. You have to turn the head with the spanner wrench as you pick the ring up to get it started out of the slot. Once you get the end of the ring started out through the slot keep turning the head til the ring comes completely out. Once the ring is out all you need to do is pull the rod all the way out til the piston bottoms against the head and pulls it out. Hope I'm understanding you right about what you've got and this helps.
jjp
10-08-2005 11:29:40
 Re: hydraulic cylinder rebuild in reply to NC Wayne, 10-07-2005 21:29:16
Thank you both for the response. What you are describing is what I"m seeing.
Thanks again...I"ll let you know how it turns out!!
jjp
10-09-2005 03:26:14
 Re: hydraulic cylinder rebuild in reply to jjp, 10-08-2005 11:29:40
Just got done with the cylinder...
worked great
Thanks again for the help!
