Tool Talk Discussion Forum
Freq. unit
Spikeman
10-03-2005 17:48:54
I have a good Century AC/DC stick welder and would like to use it as a power source for TIG welding stainless and aluminum. Does anyone out there know if anyone manufactures a tig high frequency ad-on unit that can be used in conjuction with a conventional welder? I realize a regulator, hoses, torch, etc. would also be needed. Thanks!
T_Bone
10-07-2005 21:53:48
 Re: Freq. unit in reply to Spikeman, 10-03-2005 17:48:54
Hi Spikeman,
You can scratch start Tig for SS welding that's works very well. Just use a air cooled Tig torch on DCEN.
Unless your welding alot of aluminum, Oxy/Acet gas welding works great.
To answer your question, Both Lincoln and Miller build HF add on units. For what they cost tho, it would probably be cheaper to buy a used/new machine for HF welding.
T_Bone
CNESLER
10-04-2005 16:29:07
you will not need the frequency device to TIG
stainless just set machine to DC and weld.
CNESLER
Glen in TX
10-03-2005 21:16:40
I haven't seen one of those in a while either. Century use to make a add on for those but they are now a part of Lincoln. You might look at lincolnelectric.com
Charles (49) Mo
10-03-2005 18:13:39
Have an old one. Don't know if its still available.
Sears Chraftsman
Model #934.20019
Universal High Frequency Arc Stabalizer
