Poulan 306a chainsaw
Tony Langford
01-29-2001 18:09:52
My poulan 306a chainsaw will start and run, but will not idle. How do I fix the problem?
T.LANGFORD
02-25-2001 19:03:31
 Re: poulan 306a chainsaw in reply to Tony Langford, 01-29-2001 18:09:52
I DID THE ADJ.ON CARB.LOW AND HIGH IDLE.IT DID FIX MY PROBLEM-I NEED TO LOCATE A NEW MUFFLER FOR IT NOW-CAN ANY BODY TELL ME WHERE TO GET ONE?
charlie killian
03-15-2004 11:14:20
 Re: Re: poulan 306a chainsaw in reply to T.LANGFORD, 02-25-2001 19:03:31
yes, i myself need a muffler to for my 306a. we have two of the saws now, and the one that has the complete muffler, the outer part of the muffler screws into the side of the block.
the other saw has the inner part of the muffler, but the outer part it doesn't!! the outer part of the muffler screws into the inner part unlike the other saw.
if you know anywhere to get some parts, please let me know.
thank you
D calvi
01-20-2005 18:49:47
 Re: Re: Re: poulan 306a chainsaw in reply to charlie killian, 03-15-2004 11:14:20
You can try for the muffler at lastinger cycle & lawn Located in moultrie GA 1(229)985-8839
thomas broome
06-06-2005 21:37:26
 Re: Re: Re: poulan 306a chainsaw in reply to D calvi, 01-20-2005 18:49:47
I need a tune kit for my 306a. Any ideas.
Tom
T_Bone
01-29-2001 19:50:27
Hi Tony, It should have a low idle needle adjustment. Some of the cases are marked, low, high, idle, by a screw head and that is the adjustment screw. Try turning up the idle adjustment screw first, then adjust the low needle jet. If that doesn't work change the spark plug then readjust as I described above.
Still problems then it's time to rebuild the carb.
T_Bone
