Tool Talk Discussion Forum
The Gravely bug part two.
Jeffcat
09-28-2005 20:47:46
Well the beast I brought home from the farm is now getting a couple o more attacments. Model "L" from 1962. I bought a "Rotary Plow" for it. Good golly what a huge and heavy piece of power tool. The shaft on this thing is 1 1/4 Hex bar stock! Got the stuck wheels free with a flame wrench and all of the pivots and gear box are fine. Careful sand blast and paint are next in order. Berry red is very close to the "old" Gravely red. First thing tomorrow Is to hook it up and try it out. I think that this 55 year old guy is just a little nuts? Toys is toys you know! There is always the need for another toy. .....Right..???? Jeffcat
Dannie
09-30-2005 03:56:33
 Re: The Gravely bug part two. in reply to Jeffcat, 09-28-2005 20:47:46
Had nut drilled & tapped for set screw.
JT
09-29-2005 09:21:28
Jeffcat, you do not have another toy, you have a monster on your hands. that thing has more power than anything you have ever had your hands on, nothing except lack of traction will stop it.
Hang on, and good luck
Jim
Slowpoke
09-29-2005 00:49:28
That thing is no toy. It will pull you where ever it wants to go, so hang on tight!
Dannie
09-29-2005 03:28:18
 Re: The Gravely bug part two. in reply to Slowpoke, 09-29-2005 00:49:28
Sold the 1 I had. It had plow,tiller,mowing deck,brush blades,& sickle bar.That thing got to big for me worked good few years back.Men that got it wanted the brush deck and still has not picked other things.Sold all for $250.
Slowpoke
09-29-2005 09:58:59
 Re: The Gravely bug part two. in reply to Dannie, 09-29-2005 03:28:18
Dannie, how did you keep the drive arm on the sickle bar from loosening? When I bought mine the arm hole was worn out. I ordered a new one ($75) and tightened the nut as much as I could, but in about two minutes it was loose and started to wear the key slot...what's the secret? I'm also looking for the high speed drive gears, as it's too slow for large area cutting.
jfp
09-30-2005 05:49:52
 Re: The Gravely bug part two. in reply to Slowpoke, 09-29-2005 09:58:59
I got an idea for you. There is a product called LOCKTITE that is liquid plastic. It is used for rocker arm nuts on motors that won't stay adjusted. After assembly it turns hard like plastic and won't slip but will also be removable if you need to. I have found a thousand uses for this product. Just remember to let it set 24 hrs.
I love Gravely's and can only wish I still had my 430 commercial mower.LOL
Brian G. NY
09-29-2005 14:44:07
Yep, That sicklebar mower is a great piece of work, EXCEPT for that keyed "throw" arm. I"ve even thought of attempting to weld it on!
yak651
09-29-2005 06:33:22
I picked one up at an auction (old L) with a snow plow attachment. Got it running, will have to try it this winter. Looking for a brush mower or sickle bar to cut around 100 seedlings I planted this spring, but haven"t had any look finding anything in NE WI. If anyone has some leads let me know. Sounds like you gave a guy a good deal for all that for $250.
jeffcat
10-01-2005 23:20:19
 Re: The Gravely bug part two. in reply to yak651, 09-29-2005 06:33:22
The rotary mower was the most common front end item made. There are I think five versions of it. The first two have a BIG round nut with two holes in it on top of the gear box. You do NOT want this type. The newer ones have a smooth or a big pipe plug on top. These are much better. $100.oo bucks should find you a good used one. There are two types of blades too. The single blade is almost 1/2 inch thick! the criss cross double has tow 1/4 inch thick blades. I like the double better. You will get almost a finish mower cut with it. I do know how to run a Gravely and cut many a fence row with it. You "guide " one of these beasts and think of it a a very strong willed horse.
Will let you folks know how things progress. South Jersey has the Batsto small engine and tractor show in a couple of weeks. October 16th is a Sunday and I show up with a mess of McCulloch and Mall saws. This year I will try to bring a couple of Beasts too! Jeffcat
