Tool Talk Discussion Forum
1 9/32 wrench??????
RayP(MI)
09-28-2005 18:50:13
Do they make that size? I've several nuts on 3pt hitch pins that are too big for 1 1/4" wrench. My handy dandy caliper reads 1 9/32" across the flats - nut fits the pins of a cat I 3pt hitch - 7/8" threaded end, fine threads. What's the proper size wrench?
ed in wis
09-30-2005 10:19:06
 Re: 1 9/32 wrench?????? in reply to RayP(MI), 09-28-2005 18:50:13
12 points are kind of weak for high torque applications. 6 point would hold better. Take a 1 1/4 inch wrench to your local machine shop and have them EDM a 1 9/32 hex into it.
Hermit
09-29-2005 16:32:19
Cresent wrench. Adjustable spanner.
MN Scott
10-01-2005 19:37:17
 Re: 1 9/32 wrench?????? in reply to Hermit, 09-29-2005 16:32:19
Don't forget the trusty pipe wrench. Will fit any bolt and the harder you pull the tighter it grips.
Cat Blade 48
09-29-2005 08:06:40
It is probably a Metric Size lets say 30mm or 32mm. I had this problem recently on some bolts on my 650 Dozer do you think I could find a Big Metric Combo Wrench to buy easily, No Way I needed a 30mm and a 1 3/16 seems to be the same and evidently they do not make this size.Doggon Metric anyhow. CB48
buckva
09-28-2005 18:56:38
1 and 5/16 does the trick and is a common size.
RayP(MI)
09-29-2005 06:40:01
 Re: 1 9/32 wrench?????? in reply to buckva, 09-28-2005 18:56:38
1 5/16 wrench is awful loose! (Bought one yesterday.) Am afraid to put too much pressure on it in fear that edges of nut will round off, and things will let loose on me. R
Bob
09-29-2005 07:26:52
 Re: 1 9/32 wrench?????? in reply to RayP(MI), 09-29-2005 06:40:01
I'm not normally in favor of "butchering" tools, but in this case, why not take the next smaller wrench, and, using an angle grinder, make it slightly larger, until it is a snug fit.
RayP(MI)
09-29-2005 16:49:32
 Re: 1 9/32 wrench?????? in reply to Bob, 09-29-2005 07:26:52
Bob, May have to do that - not an angle grinder project, however - would have to use a tringular file, as wrench I need to use would be a 12pt box end! Sounds like work to me!
dhg
09-29-2005 17:10:35
 Re: 1 9/32 wrench?????? in reply to RayP(MI), 09-29-2005 16:49:32
yes they were made, but are uncommon now. Find an old ford car/truck mechanic. 19/32 was the size of the connecting rod nuts on 428 cobra jet engines.
Stickler
10-01-2005 15:47:59
 Re: 1 9/32 wrench?????? in reply to dhg, 09-29-2005 17:10:35
He said bigger than 1-1/4, as in 1-9/32. But yeah, 19/32 is an oddball today that used to be common.
