Tool Talk Discussion Forum
? about amps.
Alvin NE WI
09-28-2005 17:26:11
If a motor runs at 7 amps., how many watts does that compare to?> thanks
txgrn
10-02-2005 04:53:41
 Re: ? about amps. in reply to Alvin NE WI, 09-28-2005 17:26:11
You didn't ask, but adding it takes 741 watts (as I recall) to make one electrical HP.
Since power factor is involved (true power....watts, vs apparent power....measurement of volts and amps) it usually takes more than the VxA=741 to equal what the motor is using.(PF is usually lagging due to inductive load.....hence running capacitors are added to motors to bring it back up) and then there is the effeciency of the system...motor, pulley's, gears, belts, etc.
Power companies like PF at 1. If it really gets whacko they send you a lot of power but your meter doesn't recognize it and they loose $$$.
HTH
Mark
buickanddeere
09-28-2005 17:37:18
7amp at 120V is 840 VA. 7 amp at 240V is 1680 VA. 7 amp three phase 208V is 2053 VA. 7 amp three phase 600V is 5922 VA. Watts depends on the power factor of the load. An electric motor can be anywhere from .4 to .9 even 1.0 is possible but mighty rare. An electric heater or an ordinary incadecsent lamp has a P.F of 1.0 for in this case VA also equals watts. Wiring and breakers has to be sized for VA not watts with motors or any other inductive or capacitive load.
paul
09-28-2005 19:27:36
 Re: ? about amps. in reply to buickanddeere, 09-28-2005 17:37:18
Do you divide or multiply the power factor with VA?
--->Paul
Farmall_Ryan
09-28-2005 21:01:23
 Re: ? about amps. in reply to paul, 09-28-2005 19:27:36
You multiply the VA by the power factor. Power factor is a decimal number around 1. Anything below 1 has a lagging power factor (inductive load), an exact value of 1 means a truly resistive load, and if the value happened to be greater than 1, (not common) that would be due to a capacitive load.
MarkB_MI
09-29-2005 03:58:08
 Re: ? about amps. in reply to Farmall_Ryan, 09-28-2005 21:01:23
Ryan,
If you come across one of those motors with a power factor of greater than 1, can you send it my way? I'm working on a perpetual motion machine, but the one part I can't seem to find is a 1.1 PF motor. ;=)
As buick 'n' deere correctly stated, power factor is always less than or equal to 1. Capacitive loads cancel out inductive loads.
Farmall_Ryan
09-29-2005 08:55:37
 Re: ? about amps. in reply to MarkB_MI, 09-29-2005 03:58:08
Mark,
I was talking about power factor in a general sense. I agree inductive loads such as motors will not have a power factor greater than 1. My area is in power/high voltage so to me the standpoint is to look at a customers load from an overall standpoint. Although people don't have capacitive loads overall it is possible to create a cpapcitive load if you wanted. (Although that would tend to make the system unstable).
buickanddeere
09-28-2005 21:15:17
Capacitive power factor is still a number between 0 and 1.0 . It's just that the PF is leading rather than lagging. If you had a 1000VA lagging load with a PF of .8 . And a capacitive load of 1000VA and leading PF of 0.8 fed off the same breaker. There would be no reactive current carried by the supply lines. The electrical watts and VA would both be 1600.
So if a motor had a PF of 0.8 and the VA was 1000. The watts used would be 800 BUT the entire electrical system has to be still sized for 1000VA. Or sized for 1000W as if this load happened to have been resisitive with a PF of 1.0 . DC equipment is a direct calculation as 120VDC and 7 amp would be 840 watts.
Farmall_Ryan
09-29-2005 09:01:42
 Re: ? about amps. in reply to buickanddeere, 09-28-2005 21:15:17
I guess my wording could have been a little more clear. Sorry about that.
The actual value of the power factor will not be over 1. It would be some decimal either leading or lagging, depending on type of load.
paul
09-29-2005 06:20:12
Thanks, trying to get a grip on the Power Factor & what it means.... :)
I thought electric motors with higher PF (closer to 1.0) were better & used less watts - at least at startup. But using your calculations it would appear a lower PF results in less VA or watts being used for the same hp?????
From the first explination I thought perhaps it is measuring start-up load. But doesn't seem to. That would be a factor in the original question as well, not just 'running' watts of an electric motor....
--->Paul
MarkB_MI
09-29-2005 18:14:06
 Re: ? about amps. in reply to paul, 09-29-2005 06:20:12
There sure seems to be a lot of confusion here as to what power factor is. Let me start by saying what it ISN'T: Power factor is NOT efficiency. It has no relationship whatsoever to efficiency, except as I'll describe in a bit.
What power factor IS is the cosine of phase angle between the AC voltage and current applied to a load. If you remember your high school trig, you'll know that the cosine of anything has to be between -1 and +1. However, to have a negative power factor the current would have to be leading or lagging the voltage by greater than 90 degrees, which doesn't happen in the real world.
For a purely resistive load, the current and voltage are perfectly in phase, so the power factor is unity. For a pure inductor, current lags voltage by 90 degrees, while it leads voltage by 90 degrees for a pure capacitor. You can adjust the power factor of an inductive load (such as a motor) by adding capacitance.
If a load has a power factor of less than one, that doesn't mean it's inefficient. It just means that the product of voltage and current is less than the power delivered to the load, since voltage and current are out of phase. Inductors and capacitors are just storage devices; they absorb energy from the grid, then send it right back, 120 times per second.
So what's the relationship between power factor and efficiency? For the load itself, none. However, because the power transmission lines have to carry extra current that isn't producing any power, there are power losses in the transmission line. That's why power companies don't like low power factors. And that's also why generators and transformers are rated in volt-amps, not watts.
Jerry/MT
10-02-2005 16:18:04
 Re: ? about amps. in reply to MarkB_MI, 09-29-2005 18:14:06
Great explanation! Better than my instructor in EE301.
buickanddeere
09-29-2005 15:29:42
Depends if it's a single double or triple cage rotor. The design of the main windings and rotor can be tweaked for more resistance too. This improves starting torque and lower starting current. Full load efficiency drops and percent slip increases. Power factor will be higher. You have to wire an inductive or capacity load for volt amps not watts. Count on 3 to 12 times nameplate current on startup until the motor reaches rated rpms. There is a code on the nameplate that should convert using a data book, to the inrush current increase. For the 1st 1/2 cycle when energized. The current spikes to almost DC input values before back emf is produced. When using a too small portable generator and/or long undersized extension cords.Inrush current leaves people frustrated in the dark with a smokey smell around them.
John in MA
09-28-2005 17:30:00
Depends on the voltage. Volts x amps = watts.
