Tool Talk Discussion Forum
Testing Air Condtioner
Steve-Maine
09-28-2005 03:36:02
I don't think my window air condtioner is working right. Doesn't seem to put out a lot of cold air. Can you use a thermometer in front of air output to see if it is working right? Thanks
R Bedell
09-28-2005 05:22:11
 Re: Testing Air Condtioner in reply to Steve-Maine, 09-28-2005 03:36:02
To test your Window A/C, you need to measure the difference between input and output. Hence, measure the temperature of the return air (going in at the front grill) and the supply air (top of grill blowing out). At high fan speed you should be between 10 and 15 degrees with the discharge air being colder. If less than 10, then you have an issue(s).
Correct..John,PA
09-28-2005 09:34:59
 Re: Testing Air Condtioner in reply to R Bedell, 09-28-2005 05:22:11
10 to 12 deg. TD (temp. difference) is pretty good. HTH
Dick2
09-28-2005 04:35:02
Have you cleaned the coil recently? If you can, remove the front cover and see if the coil is plugged. I have a window AC in my workshop. I fixed the cover so I can just lift it off and vac and blow out the coil every day (or oftener) if I make any dust at all in the shop. The filter doesn't catch much, so the coil can still plug.
