Tool Talk Discussion Forum
Blades for a 10 inch table saw.
J. Schwiebert
09-23-2005 16:43:25
I have a 10 inch table saw that has a 3/4 inch mandral instead of the usual 5/8 inch. Anybody know who has blades for this size.?
DaveCA
09-24-2005 08:42:13
 Re: Blades for a 10 inch table saw. in reply to J. Schwiebert, 09-23-2005 16:43:25
Ridge Carbide shows a $14 charge for different (not 5/8) bore size for their new 10" blades.
I have one of their dado sets and am pleased with the quality. I have used it with my Unisaw quite a bit on hard Hickory. Not cheap, but built to last.
If you have some old dull blades worth sharpening, they do sharpening.
Slowpoke
09-24-2005 02:11:26
Ask you local saw shop or wood working tool supplier for that size. If you want to use standard 5/8 hole blades, you might consider buying a step drill that cuts to 3/4 or more. They cut nice true holes in thin stock, and are great for enlarging holes, too. I think the center of a saw blade would be soft enough to use one. Test the hole with a small file first. You don't want to try cutting something hard as it will ruin the $30 bit real fast. Try it on a scrap blade just to be sure the blade will still run true. Brand names are Lenox Vari-Bit, and Irwin Unibit.
J. Schwiebert
09-24-2005 06:42:54
 Re: Blades for a 10 inch table saw. in reply to Slowpoke, 09-24-2005 02:11:26
The last two I purchased were from Sears. It was sales pitch thing. If you purchased an adjustable dado they threw in a 10 inch Carbide blade. That was probably 15 years ago. I have a tapered reamer and we have been doing that for about 30 years off and on. I appreciate the information on the step drills. Thanks.
mrfu
09-23-2005 20:48:49
Forrest will bore any size hole in there blades, but there blades are expensive ($100 +), any good saw sharpening shop should be able to machine a 5/8 hole up to 3/4. good luck
Steve/TN
09-23-2005 19:48:23
I am sure that I have seen blades with a 5/8th hole but has a bushing that you can knock out for the 3/4" arbor. I could be wrong, but I think I have seen 'em sommeres.
kraigwy
09-23-2005 17:50:26
buy the 5/8 spindle blade and get a bushing, any hardware store sells them
kraigwy
09-23-2005 17:51:07
 Re: Blades for a 10 inch table saw. in reply to kraigwy, 09-23-2005 17:50:26
sorry miss read your post
K
