Tool Talk Discussion Forum
Clutch for small engine
CBBC
09-20-2005 20:42:53
I'm looking for a clutch which mounts directly onto an engines' shaft (9hp honda). The one I used before had a leaver which would slide one way to engage, back to dissengage. When engaged, the sprocket will turn driving a 40 P chain on a conveyer.
This is not a centrufical clutch (at least I don't think it is) as it will engage or dissengage at any rpm.
Any idea what it is called, who makes them or where I can get one.
Thanks, Grant
buckva
09-21-2005 15:41:45
 Re: Clutch for small engine in reply to CBBC, 09-20-2005 20:42:53
I have one of those clutches that came off a JD model 70 7 HP. Slides back and forth or up and down to engage mower deck. made for belt but I guess It could be adapted to chain. Believe it is 7/8 shaft. If interested it's yours for postage
CBBC
09-21-2005 16:53:15
 Re: Clutch for small engine in reply to buckva, 09-21-2005 15:41:45
Where are you? What is the approximate size of the unit? A or B belt? I will check the shaft on my engine.
Grant
email is open
Bob
09-20-2005 21:46:35
You may be able to use an electromagnetic clutch, such as is used on riding lawn mowers, or adapt the mechancial mower clutch from an older Cub Cadet.
Or how about these links...
Link
http://www.surpluscenter.com/sort.asp?UID=2005092023452459&catname=&byKeyword=yes&search=clutch
CBBC
09-21-2005 16:55:34
 Re: Clutch for small engine in reply to Bob, 09-20-2005 21:46:35
Thanks for the info Bob. I appreciate it.
Grant
