Tool Talk Discussion Forum
Air Compressor Tank
DLM
09-20-2005 20:27:17
My compressor tank is rusted out it is a 20 gal. tank. Surplus Center has new ones at 120.00 but they are not ASME certified. Has anyone used one of these tanks? Granger has tanks there price is 225.00 What do most of you do when a tank rust out? The compressor & motor are still in good condation the comp. is a heavy cast iron unit & the motor is a 3 HP 220 Volt. Any thoughts on this . Thanks Don
Jay87T
09-21-2005 04:14:56
 Re: Air Compressor Tank in reply to DLM, 09-20-2005 20:27:17
I was using a 40 Gal propane tank for along time with my 10 gallon crappy compressor, untill I got big 60 gal compressor.
Jay
Crem
09-20-2005 21:30:33
When the tank went bad on my brothers compressor, he cut the end out of the old tank and bought a portable air tank that would slide inside of the old tank. I don't know he connected the pressure switch and relief valve, but I believe that he can uncouple the portable tank and take it out in the field if needed.
old
09-20-2005 20:30:16
Maybe a propane tank, seen them used that way a lot and a 20 gal. one is cheap.
BillD1
09-21-2005 05:22:10
 Re: Air Compressor Tank in reply to old, 09-20-2005 20:30:16
You can probably beat the Grainger price by shopping around Do not use a tank without the ASME stamp could be a potential bomb
cannonball
09-21-2005 06:08:23
 Re: Air Compressor Tank in reply to BillD1, 09-21-2005 05:22:10
i have a 20 inch pipe i use..not worried about asme was under 1000 psi working pressure when removed.. have nice one may god bless
