Drill motor lubricant
Dubya Dee
01-29-2001 04:39:35
The greese that comes in new drill motors, angle grinders, and such seems to get thrown out of the gears. I've heard that there is a special purpose lubricant that sticks in there better. Can anyone tell me a brand name and number that is sold in small quantities.
Jon Hagen
02-01-2001 11:09:40
 Re: Drill motor lubricant in reply to Dubya Dee, 01-29-2001 04:39:35
Have tried repacking with the normal #2 grease we use around the farm but it won't run/melt into the gears, just as bad as the original stuff. I tried #1 molly grease and it works well, just a little heat from the tool will soften it so it flows into the gears.Was worried that it might make the gear case leak under continuous use ( hot) but has not been a problem.
Neil
01-29-2001 08:45:20
You might try something like "CV joint Grease"
The good stuff is Molly based.
Land Rover/Range Rover has a more liquid form they use in their front CVs. It might flow back onto the gears better than the thick stuff typically found at German car parts places.
Fred OH
01-30-2001 12:22:27
 Re: Re: Drill motor lubricant in reply to Neil, 01-29-2001 08:45:20
I tried to be nice to an old angle grinder because it had run for years with no complaints. So, I cleaned out all of that dried grease and filled it with new. Put it back together and ran it a few and reached up and touched the gear case and it was so hot it burnt my hand. I had to clean it out again, I think I took about half of it out and put in about a tablespoon of 30 wt oil. That did the trick for me. TYLTK L8R----Fred OH
