Tool Talk Discussion Forum
Woodsplitter plans
Case450
09-19-2005 13:40:50
Winters coming and I would like to build a hydraulic woodsplitter from scratch. A project like this would keep me busy for a bit. Now I have a couple of old hydraulic cylinders (from an old allis chalmers D-14 three point hitch i believe) there not very big. If a big cylinder is needed i can get one fairly cheap and fairly easily. What I would be looking for is a parts list or some blueprints or diagrams or something to get me started. Any help would be appreciated.
Glen in TX
09-20-2005 08:02:50
 Re: Woodsplitter plans in reply to Case450, 09-19-2005 13:40:50
I once had a good welding plans book from Lincoln Electric that makes the welders. Loaned it out and it never came back :( You can find them at www.lincolnelectric.com . Also a couple places for hydraulic goodies are: www.surpluscenter.com and www.northerntool.com
I found a piece of 12" I-beam and a 4x40" cylinder from military surplus guy and V4 Wisconsin at auction that I'm using to build one with. Now I got to figure what size pump to use. The Surplus Center catalog has some formulas to help you figure that stuff too.
holt_2ton
09-20-2005 05:42:15
The bigger the cylinder the more pressure you will have to force it"s way into the log with the same ammount of input pressure. Force= pressure X area of cylinder PISTON, NOT cylinder rod). I also built mine so that my cylinder(4"X 24") with the pusher on it stops an inch from the wedge. I also measured the opening of my wood stove(18") and ground a line in the top of the beam. I also put one at 16"(the length I like) so that if a log is cut longer than 18" I know I need to re-cut it. I used the two-stage hydraulic pump from Tractor Supply Co. It has a stage with faster speed, then when force increases it automatically switches to slower speed but more force. Works very well.
coup
09-20-2005 03:58:13
heard tell of a guy making one powered by a power steering unit from a car...they make them for 3pt uno....
Slowpoke
09-20-2005 01:11:50
Go to ebay and type in "welding projects". There's 8 or 10 books of plans including one for farm projects. You might find one at the library.
Slowpoke
09-20-2005 01:33:17
 Re: Woodsplitter plans in reply to Slowpoke, 09-20-2005 01:11:50
I have the two volumes in shown in #7547920281. Got them last year for about $12/both. I don't know why, but Volume 1 is never offered.
vinnie
09-19-2005 18:17:37
Iwent down to the rental shop and came home with a lot of good ideals
