I've never done anything like this, but I pondered it a few times before I built the 60x60 aircraft hangar in my back yard. Without original drawings you have little choice but to make your own drawings, as detailed as you can get, and number all the pieces before it comes apart. Probably some sort of white paint marker. Leave as many parts together as you can, such as purlin clips attached to the purlins or beams, and when you get it down, you will need to carefully measure and draw out the stud patterns. I wouild take lots of digital photos, lots of them, several of every joint in the building. get as organized as you can, set out buckets for hardware to go in, the more you save, the less you will need to buy. Remember you will need 4x4's and 2x4's to set parts on on the truck or trailer and if you are hauling this yourself, you will need lots of good ratchet straps, etc, to safely secure it to the trailer or truck. You don't want to lose parts, or damage them. tip, Home Depor has AMERICAN MADE 2" wide, 10,000 lb ratchet straps, 27 ft long, for about $14. They keep creeping up in price, I bought two at $12, two more later at $13 and now they are $14 or so, best deal going, get 6 or 8 of them minimum. Make sure you note the diameter of the anchor bolts, and other important dimensions that you may not be able to go back and get later on. As far as a slab goes, I would talk to a metal building company, they may give you some ideas. You are going to need several people and equipment to get this apart and down without damage to the building or yourself. You might just want to consider contracting the slab to someone who does this for a living. Charles
