Tool Talk Discussion Forum
ot=chainsaw question
vabill
09-18-2005 17:19:59
i have a poulan 3050. i finally got it running good and now the oiler i gtving me problems.. i took it apart and cleaned it real good i thought. put it back and it still dont work. what is the right way to clean it????? ?. bill
JT
09-20-2005 06:31:59
 Re: ot=chainsaw question in reply to vabill, 09-18-2005 17:19:59
Most of the newer poulan saws have a gear driven oiler, plastic gears that will get eaten out real easy, then they do not oil. Take off the bar and chain, there is a little cover there, take it off, the oiler shoudl be right there. A new oiler should be about 12-15.00 depending on where you are at.
Saw Dust
09-18-2005 20:17:33
Vabill I had this same problem years ago you will have to trace the oiler back to the carb there you will find the oil pump that runs the oiler take it apart you will find a diaphram with a long spindle buy a new one and at the same time buy a new gasket, after I did this everything ran good again.
Gene Davis (Ga.)
09-18-2005 17:24:21
Many times the oil hole in the bar itself is the culprit.
vabill
09-18-2005 17:35:22
 Re: ot=chainsaw question in reply to Gene Davis (Ga.), 09-18-2005 17:24:21
gene the hole on the bar is clear. can the oiler be taken apart????? ??? bill
Gene Davis (Ga.)
09-18-2005 17:40:10
 Re: ot=chainsaw question in reply to vabill, 09-18-2005 17:35:22
Not real sure on that saw. Used to work on saws a lot back in the 50's 60's & 70's, but sort of lost touch with them now. Sorry!
