Tool Talk Discussion Forum
Swing Cylinder on a 93 sreiesA Backho 1969
sandman
09-17-2005 15:52:45
Tapered pin, (2 used) JD part# U 41078 My question, how is the pin removed as to check the seal washers on the Swing Cylinder? I have to rotate the cylinder after removing 2 hyd. lines & at least 1 of the 2 tapered pins! I'm in the dirt moving business, and I'm broke down! Has anyone out there removed tapered pins before?
Roy Suomi
09-21-2005 19:47:13
 Re: Swing Cylinder on a 93 sreiesA Backho 1969 in reply to sandman, 09-17-2005 15:52:45
They're no fun. I've spent hours on some. I made a "bridge" of a larger bushing by cutting out 2 slots on either side so you can get a heavy punch to the tapered bushing. Place the bridge over the tapered bushing , use a heavy, heavy, washer on the top of bushing then put a bolt into the threads of pin.Turn the bolt to put presure on the pin, and hit the tapered bushing with the punch thru the slots. It might take a while but it usually works..
Rezvan
09-23-2005 09:03:18
 Re: Swing Cylinder on a 93 sreiesA Backho 1969 in reply to Roy Suomi, 09-21-2005 19:47:13
Hi, Dear sear. Please send me cataloge of backho tractor of model LB90.B, LB95.B, LB110.B, LB.115.B.
Best regards,
R. Zolfagary
NC Wayne
09-17-2005 21:19:51
Hey Sandman, I'm not sure on the Deere how exactly the pins are installed and held in place, but typically the only way to remove a tapered pin is to drive it out with a soft (brass, aluminium, etc) punch. If there is a threaded hole in the large diameter you can put a tube around the pin as a standoff. Then get a heavy "washer" and a bolt and pull the pin out. Even doing it this way your probably gonna have to use the soft punch and give it some help. Now the way your talking the only reason your wanting to pull them is to check the seals. If that be the case I wouldn't waste my time just for that purpose. Just about all the makers use the same type seals and I've not taken but a few apart that the seals in the swing cylinders were hurt, and typically those were ones where the bushings had disentegrated from lack of lubrication. I've worked on older machines without the seals and the "newer" machines with every joint sealed and based on what I've seen, sealed or not, they all wear out eventually but as you would expect the life exectancy is alot longer when properly greased. As long as you grease it properly very little dirt will ever get past the layer of grease around the outside of the joint and any that does will get forced out when you grease the joint the next time. Good luck.
