Tool Talk Discussion Forum
box blade
gene Johnson
09-14-2005 06:47:41
Can someone tell me what a 6 ft. rino boxblade will wiegh. It is a heavy duty with the big system that raises and lowers the ripper teeth and the back blade is hinged. I know it at least a 1000 lb. Thanks
Charles (in GA)
09-15-2005 18:10:27
 Re: box blade in reply to gene Johnson, 09-14-2005 06:47:41
Gill/Woods also makes a box blade with a mechanically raised scarifier (via lever, reaching from drivers seat) and the 72 inch model weighs 966 lbs.
I have a Gill/Woods R10 roll-over box scrape. It is 65 inches, they no longer make this one but have gone down to 60 inches, it is 728 lbs, mine is about 750 lbs if I recall. It is heavier than an identical one a neighbor had, that is about 30 years old. The roll-over feature is a little bit of a hassle, but very useful.
From my inpromptu research, I don't think that a 72 inch box will run in excess of a 1000 lbs if that, no matter the age or type. Most seem to run in the 850 lb range. LandPride for example runs from a low of 504 lbs to a high of 994 lbs for 72 inch models.
Charles
krazy-ken
09-15-2005 06:42:12
Gene are you located by smoken Bobs. ken
Gene Johnson
09-15-2005 07:24:56
 Re: box blade in reply to krazy-ken, 09-15-2005 06:42:12
Afraid so, did'nt know you were smart enough to use the computer. Amazing
krazy-ken
09-15-2005 15:20:06
 Re: box blade in reply to Gene Johnson, 09-15-2005 07:24:56
Thanks to Harley my Hog riding friend I can a little.Dont under stand why another aircraft driver would not show me????? ??AND TRACTOR LOVER.Must be wrong color.ken
Charles (in GA)
09-14-2005 18:56:45
If you mean Rhino products, their current box blades are the BX series, the 72 inch being the BX72 and it weighs 505 lbs.
The HB series has hydraulic raise and lower on the scarifiers, and the HB72 is 958 lbs.
Charles
Charles (in GA)
09-14-2005 18:58:48
 Re: box blade in reply to Charles (in GA), 09-14-2005 18:56:45
Just to add a link to the BX series blades by Rhino.
Their home page is.....
Link
gene Johnson
09-15-2005 07:30:08
 Re: box blade in reply to Charles (in GA), 09-14-2005 18:58:48
Thank Charles, This one is older ,machanical control for the rippers and looks much heaver built, Thanks for the info. Gene
Slowpoke
09-14-2005 09:50:07
Ask the manufacturer. But I think the name's spelled differently.
