Tool Talk Discussion Forum
wierd open end wrench
dr.sportster
09-13-2005 20:06:08
Do you gentlemen know if anybody makes an open end wrench or wrench set that has a handle you can move to different positions.I have this AN 6 hose end on my panhead that I can barley get at.I have the snap- on wrench that has the odd angle.That helped turn it in a turn and I made an aluminum wrench[5/8"] with a straight no angle and got another flat or so and eventually removed the brakelight switch and got it tight.But since it took two afternoons to do this: I thought there might be a ratcheting open end or something that might have worked easier. Or maybe not ratcheting but a two position handle maybe.Is there any such thing or am I delirious.
dr.sportster
09-14-2005 13:28:05
 Re: wierd open end wrench in reply to dr.sportster, 09-13-2005 20:06:08
Thanks.I might even have a crows foot.I have the mini ratchet.Should be good to go.Size was 11/16 anyway not 5/8 but you guys have solved the problem.
old dude
09-14-2005 02:58:27
snap-on,proto,and most pro. tool manufacturers make 37.5 & 22.5 degree wrenches along with crows feet but you won"t find them at harbor freight. LOL. old dude
Farmer in the Dells (WI)
09-14-2005 10:25:17
 Re: wierd open end wrench in reply to old dude, 09-14-2005 02:58:27
Was also thinking about a crows feet wrench or a wobble socket. Sears, NAPA, Snap On or MAC should have either one
09-14-2005 10:45:15
 Re: wierd open end wrench in reply to Farmer in the Dells (WI) , 09-14-2005 10:25:17
third party image
I meant to say "wobble extension"
Scott In Sandpoint
09-13-2005 23:25:42
third party image
Dr,
Farmered is correct.
you can get crowfoot wrenches at Sears and other locations.
I picked up a set thru ebay about a year ago and only used them a couple of times, but they are one of those tools you seldom use but can't do without under certain circumstances.
Scott
ShepFL
09-14-2005 09:45:06
 Re: wierd open end wrench in reply to Scott In Sandpoint, 09-13-2005 23:25:42
Scott -
How is the weather back home? Still flat, hot, muggy & buggy here in FLA :)
Scott In Sandpoint
09-14-2005 16:36:11
 Re: wierd open end wrench in reply to ShepFL, 09-14-2005 09:45:06
third party image
Shep,
Just miserable.
Low 70's daytime, high 50's at night. Nice cool breeze that starts about 5:30 PM, just right for boating and sleeping with the windows open. 1/2 hour of rain about every other day, other than that humidity running about 22%.
Farmered
09-13-2005 22:46:27
Yes. They are called crowfoot wrenches and snap on to your 3/8 ratchet, extension or breaker bar.
They come in open end and flair nut configurations. If you need an angle between just turn it over. Snap On or Craftsman have them. Ed
Farmered
09-13-2005 22:45:55
