Tool Talk Discussion Forum
Square Bend U-Bolts
jd05
09-13-2005 11:12:04
Having trouble finding some square bend U-Bolts that are larger in diameter than what's at your hardware store. Was wondering if you guys know a supplier where I can order. Looking for these sizes:
2x5, 1/2 inch diameter
4x7, 3/4 inch diameter
Thanks in advance for your help.
Doug in IL
09-14-2005 08:05:46
 Re: Square Bend U-Bolts in reply to jd05, 09-13-2005 11:12:04
I think you can get those from NAPA. Our local store has a rack full of them. They can probably order them for you, if they don't stock them.
Eddie in MI
09-13-2005 18:29:22
You can try these folks:
Link
I've been to their showroom / warehouse and the inventory is astounding!
Missouri Boy
09-13-2005 17:19:27
Make a couple of pieces of one half by one and one half flat and use machine bolts. Works great
Vern-MI
09-13-2005 14:00:06
Or try this company..... ...
Vern-MI
09-13-2005 13:57:39
Try these people..... ..... .
thejdman01
09-13-2005 13:53:06
i agree with illinois boy however the problem is if you get grade 8 threaded rod bending it can create stress cracks and stress risers. softer rod can be bent with ease without anyworries but then again its only grade 5. dont know what your workign on how much strength you need
jd05
09-13-2005 13:59:41
 Re: Square Bend U-Bolts in reply to thejdman01, 09-13-2005 13:53:06
They need to be strong. They go go a frame I'm building to hold forklift forks which will eventually be used on a tractor loader. Would this work? Use that 1/2 inch solid steel round stock you can buy at most hardware stores, heat it, bend it then use a pipe threader to thread the ends? Would this work?
Mike M
09-13-2005 12:32:43
Our local spring and alignment shop can bend them up for you. Check and see if you have anyone locally.
JMS/MN
09-13-2005 11:39:18
Have you checked with implement dealers? A lot of field cultivators, chisel plows, disc chisels, etc. use square bend U-bolts to hold shanks to the frame. Our JD dealer handles them for many brands and generics.
Illinois Boy
09-13-2005 13:35:15
 Re: Square Bend U-Bolts in reply to JMS/MN, 09-13-2005 11:39:18
I just go to the hardware store and by a piece of thread-all and bend them to fit.
Doyle Alley
09-14-2005 09:50:07
 Re: Square Bend U-Bolts in reply to Illinois Boy, 09-13-2005 13:35:15
Check your nearest trailer supply store. They are frequently used on trailer axles.
