Tool Talk Discussion Forum
how many Gallons in a bushel
Shelled Corny
09-13-2005 04:34:18
Try'n to figure out how many bushels of shelled corn I can fit into a 55 gallon drum, who's good with math?
KELLY ONEAL
09-13-2005 12:12:39
 Re: how many Gallons in a bushel in reply to Shelled Corny, 09-13-2005 04:34:18
IT TAKES ABOUT 300 LBS OF CORN TO FILL A 55 GAL DRUM (A BARREL IS ALOT LESS THAN A DRUM) IF YOU ARE MAKING A DEER FEEDER. WHEN YOU ADD YOUR FUNNEL IN THE BOTTOM OF THE BARREL YOU WILL REDUCE THE AMOUNT OF CORN TO AROUNR 250 LBS. HOPE THIS ANSWERES YOUR QUESTION.
JMS/MN
09-13-2005 11:43:57
Volume (in cubic feet) times .8 equals one bushel. A gallon is about 235 cubic inches? Plus the others already got you in the neighborhood.
Vern-MI
09-13-2005 15:27:24
 Re: how many Gallons in a bushel in reply to JMS/MN, 09-13-2005 11:43:57
231 cubic inches per gallon to be exact.
4000 deere
09-13-2005 11:35:40
55 divide by 5.9081484 = 9.3091771 gal per bu.
4000 deere
09-13-2005 11:15:39
7.4805195 gal. per cubic ft.
.803564 bu. per cubic ft.
55 divide by 7.4805195 = 7.3524305 cubic ft.
7.3524305 x .803564 = 5.9081484 bu. per barrel
Rod in Smiths Falls, ON,
09-13-2005 07:58:13
1 barrel (bbl), standard for fruits, 7056 cubic inches.
vegetables, and other dry 105 dry quarts.
commodities, except cranberries 3.281 bushels, struck measure.
http://ts.nist.gov/ts/htdocs/230/235/appxc/appxc.htm#2
CBBC
09-13-2005 15:43:23
 Re: how many Gallons in a bushel in reply to Rod in Smiths Falls, ON, , 09-13-2005 07:58:13
Rod, how do you know about cranberries?
By the way, 1 bbl cranberries is always 100 lbs, little to do with volume. We bulk load 40 foot containers, they will hold anywhere from 400 -650+ bbls fruit full. Thats a lot of weight and we need to be carefull even with a tridom underneith. There are lots of variables which can cause this discrepancy in weight - variety, pollination, growing conditions etc.
Grant
dbwillia
09-13-2005 07:48:41
It would be 6 and 7/8 bushels according to my calculations.
Mark57_420
09-13-2005 10:44:54
 Re: how many Gallons in a bushel in reply to dbwillia, 09-13-2005 07:48:41
1 bushel = 32 quarts
1 gal = 4 quarts -> 55 gal = 220 quarts
220 quarts/(32 qts/bu) = 6.785 bushels
Steve Crum
09-13-2005 06:08:24
As a general rule, corn in the 12% H2O range will run approx. 56 pounds to the bushel. I have the equasions at work somewhere to calculate pounds per cubic foot for corn. The standard for corn is pounds per bushel weight though.
Bus Driver
09-13-2005 04:58:20
A bushel of corn for marketing purposes is defined as a certain weight at a certain moisture content. By volume, a bushel is defined as 8 gallons.
Rauville
09-13-2005 04:53:44
8 gallons in a bushel...it would take a math major to figure out the rest of the equation.☺☺☺
BillD1
09-13-2005 06:36:26
 Re: how many Gallons in a bushel in reply to Rauville, 09-13-2005 04:53:44
It really depends on how many times you run it through the still. The higher the proof less volume
Oliver
09-13-2005 06:45:26
 Re: how many Gallons in a bushel in reply to BillD1, 09-13-2005 06:36:26
And samples, don't forget you've got to keep sampling it, and that takes away from the finished product.
Rustyj14
09-18-2005 14:12:43
 Re: how many Gallons in a bushel in reply to Oliver, 09-13-2005 06:45:26
All depends how tight the cracks are in yer bushel basket!
