Tool Talk Discussion Forum
Wanting to build cheap water tank.
Chances R
09-11-2005 20:17:29
Our local 4-H Center is in need of a water tank on wheels to water pulling tracks and to knock the dust down on gravel roads during events. Does any one have any good ideas for a 500 - 1000 gallon tank with motor and gas engine pump. Is a anhidrous tank a bad way to go? I think they scrap these from time to time?
kippster
09-13-2005 10:44:14
 Re: Wanting to build cheap water tank. in reply to Chances R, 09-11-2005 20:17:29
we took a flat bed hay wagon with tandem rear gears and put a 1000 gal poly tank from Tractor supply on it with a 5 horse jet pump and pvc pipe with holes drilled in it along the back with a T-fitting in the middle. Fastened it on the back with hose clamps. works great. we pull it with an Allis Chalmers 190XT with the turbo.
Weirsdale George
09-11-2005 21:27:12
My club has two watering vehicles -- one used to be a gas truck and the other, a propane truck.
