Tool Talk Discussion Forum
Locking fuel oil cap
diggerdave
09-08-2005 10:49:58
Hi all- wondering if any of you have any thoughts on how to secure a locking home heating oil fuel tank filler cap. I got a hunting �shack� in the woods and Im thinking of adding a locking cap � the kind you can get from General filter for example. It appears they screw on and they you add your own lock. Is there a way to secure it once it is screwed on? It would seem that to defeat it you just unscrew it..I know that seems like a lot of work and you need a pipe wrench etc but im just trying to cover my bases so the oil stays put if you know what I mean. A tack weld would seem pretty risky?? Loctite??? Any thoughts? Much appreciated. dave
MAC,IL
09-08-2005 11:29:07
 Re: Locking fuel oil cap in reply to diggerdave, 09-08-2005 10:49:58
There is a pretty health cap on here.
http://www.preferredutilities.com/spill_fill_containers.asp#lockingfillcaps
MAC,IL
09-08-2005 11:22:53
Clean the threads and use some type locktite. I dont remember off hand which one it is, but some of that locktite sets up and it had to be heated real good to unscrew it. Might even figure how to put a lock screw into the sides of the threads, then saw the head off. But if someone wants it that bad, they will cut the lock anyhow. Or loose the outlet line. Locksd are to keep the honest people out.
Gene Davis (Ga.)
09-09-2005 18:57:14
 Re: Locking fuel oil cap in reply to MAC,IL, 09-08-2005 11:22:53
The red Locktite has to be heated to about 400 degrees to loosen it according to their instructions.
aa
09-08-2005 20:38:58
use blue locktite, i used a 4 foot pipe wrench to snap off a hitch ball locktited on.
