Glenn --In the years before World War II there were two different series of standard-size nuts used in the US, the Standard [also called Society of Automotive Engineers (SAE)] and the Heavy. The across-flats dimension of the Standard nut was 1.5 times the nominal thread diameter of the corresponding bolt, while the Heavy was 1/8 inch larger than the Standard. This meant that any "odd-sixteenth" bolt ended up with "odd-thirty-second" nut sizes in both the Standard and Heavy series. To work one numerical example, let's consider the 5/16 inch bolt. Its Standard nut would be 1.5 x 5/16 inch = 15/32 inch, and its Heavy nut would be 1/8 inch (4/32 inch) larger at 19/32 inch. If you calculate the Standard and Heavy nut sizes for 7/16 inch and 9/16 inch bolts, you'll see what nuts your seldom-used sockets were intended to fit. During WWII the use of odd-sixteenth bolts generally fell into disfavor, although the 5/16 inch size has survived fairly well to this day. John
