Tool Talk Discussion Forum
inch pounds to foot pounds of torque?
johnlobb
09-05-2005 16:51:13
I have a 1950 JD B and I suspect the pushrod tubes are leaking so I must remove the head. I bought the service manual and it says to torque the head nuts on the studs to 1150 inch pounds. My torque wrench is rated in foot pounds. Do you divide the inch pounds by 12 (seems logical) or use some other multiplier? Thanks Johnlobb
Mike M
09-06-2005 04:54:52
 Re: inch pounds to foot pounds of torque? in reply to johnlobb, 09-05-2005 16:51:13
If you have push rod tubes,yours may be new enough it doesn't,You can change them without pulling the head off.
dan67
09-05-2005 19:36:48
bobm is right on the money
Bob M
09-05-2005 17:00:59
You got it! Inch pounds divided by 12 will give you foot pounds. (I.e. 1,150 in-lb = 96 ft-lb.)
