Tool Talk Discussion Forum
Gas line sealant??
Bilko
09-01-2005 16:05:08
Does anyone one use any type of sealant on fittngs to the carb or fuel tank so it doesn"t leak? And if you do what works the best. Thanks Mike from MI
Bilko
09-02-2005 19:17:32
 Re: Gas line sealant?? in reply to Bilko, 09-01-2005 16:05:08
Thanks guys for the information! I am putting a new sediment bowl and rebuild carb and new gas line. Just was wondering what everyone used before I had gas all over!!!!! Thanks again MIke from MI
RB/CT
09-02-2005 15:56:49
Loctite Teflon pipe sealant comes in a small tube. It is like Teflon tape, only liquid. Use it all over with good relults.
Vern-MI
09-02-2005 06:39:26
Depends on if you are talking rubber hose connection to a barbed fitting, a double flare tube fitting, a pipe thread fitting, or a straight thread gasketed face / 'O'-ring seal fitting. For double flare fittings they have copper conical washers which fit between the tube flare end and the mating brass or steel fitting to restore the seal. For a rubber hose to barbed fitting I have always used clear nail polish to glue the two together. Pipe threads in good condition use teflon tape and place it back from the leading edge to the male fitting so it does not shear off and float down stream to cause trouble. Straight thread fittings require a new seal gasket / washer or 'O'-ring to regain the seal.
Mike M
09-02-2005 03:45:39
Permatex # 1 or # 2 depends on if you want hardening or non hardening.
Slowpoke
09-01-2005 23:38:21
The fittings or tube ends are out of round and won't seal. Replace them with new.
buickanddeere
09-02-2005 05:23:54
 Re: Gas line sealant?? in reply to Slowpoke, 09-01-2005 23:38:21
Amen. Why not just repair it rather than wait for ga$oline to leak all over the hot engine?
Mike M
09-02-2005 19:38:30
 Re: Gas line sealant?? in reply to buickanddeere, 09-02-2005 05:23:54
Have you ever tried to get a pipe thread sediment bowl to lime up where you need it and not be loose and one more round was going to break something ? This is where the hardening permatex (#1 I think)works real good.Put it where you need it and let it harden and it seals it up.
Charles (in GA)
09-01-2005 16:50:09
Titeseal.
absolutely gasoline proof.
Charles
