Tool Talk Discussion Forum
Welding broken plastic water tank
Leland
08-30-2005 19:21:36
moron neighbor used my tank and stood on top of it and cracked it around filler hole can you buy plastic rods and weld it shut with some heat source anybody know ?
Keith-OR
09-05-2005 07:47:30
 Re: Welding broken plastic water tank in reply to Leland, 08-30-2005 19:21:36
I have used windshield urathane for repairing everything from chest waders, to holes poked in the bottom of car batteries. Also used it to repair crack in bottom of chemical RV holding tank. That stuff will stick to just about anything, but darn hard to get off your hands, has to wear off with every washing..LOL..Keith
Ever Think of This
09-01-2005 16:19:39
Tell your moron neighbor the tank is now his, and that you will be waiting for him to deliver you a new replacement. If it cracked in normal use, then I would not do this. BUT standing on it and breaking it made it his problem.
Leland
09-01-2005 16:38:32
 Re: Welding broken plastic water tank in reply to Ever Think of This, 09-01-2005 16:19:39
I would but his name is p!ss poor
Slowpoke
09-01-2005 01:47:12
I have two products that are for plastic tank repair. One is Cargo Plastic Tank Repair and the other is Seal-All which is an all purpose contact adhesive and sealant, gas & oil resistant. The Cargo is an epoxy kit that uses fiberglass. Cargo: Blue Magic, Inc. Conroe, Texas. 936-539-1555.
Seal-All: Eclectic Products, Inc. Pineville, La. 800-767-4667 for technical assistance.
John F in MD
08-31-2005 08:58:16
I have a 100 gal tank that I use for Electrolysis that devleoped a crack near the drain. I used Marine Goop. It's holding up fine so far.
MAC,IL
08-31-2005 06:40:57
I"m glad i aint the only one with a moron neighbor. I think I would rough it up and try some fiberglass kit. The one that uses the tape in repairing.
Farmer Gene (NW WI)
08-31-2005 02:01:43
You could try an electric glue gun, they make sticks of glue for different materials, or automotive fiberglass might work.
Truetramp
08-30-2005 23:01:10
I've tryed welding them an got the same problems that the other guys have stated too, it just don't last. So when i find one thats cracked i turn them into doghouses, they are great...Rick
drw
08-30-2005 19:32:26
Yes, you can. You need to identify the type of plastic your tank is made of, this is easier than it sounds. Urethane Supply Company & Seelye both make platic welders & filler rods; I think that the USC unit is easier to use. I think most models come with a chart to ID your plastic, by either special markings on the tank or a "burn"
test if you have some scrap to spare. Look for these at a local PBE jobber/supply store in your area or on the Internet.
msb
08-30-2005 19:56:01
 Re: Welding broken plastic water tank in reply to drw, 08-30-2005 19:32:26
www.usplastics.com is another source as is Harbor Freight .You really need a way to adjust the heat which the el cheapo HARBOR FREIGHT doesn't have,but if you have a 120 volt rheostat it will do fine.HF welder is only something like $39.95 and comes with a selection of rods.Unfortunately it doesn't come with an identification chart. Welding plastic is an aquired skill like most eveything else.It is very easy to burn plastic.The main thing is to push the rod into the area to be welded when the heat is just right.Chances are your tank is polyethylene and can be somewhat of bear to weld if it is an older tank.The plastic gets brittle after so many years of exposure to sunlight.I had one tank that could not be welded.it was too brittle.The clod may have actually done you a favor if the tank was that brittle.Filled with fertilizer of worse yet chemical solution and have the tank fail could be a disaster if you don't carry polution insurance.I would seriously consider buying a new tank and forget the welder and aquiring the skill to do a good enough job that you could be assured of the old repaired tank's integriry.
