Tool Talk Discussion Forum
Stuck PTO shaft ?
TomWNC
08-28-2005 13:03:48
I have a PTO shaft that is telescoped all the way down (short) and stuck. This is on a piece of equipment that was given to me and I have no idea how long it has been sitting. Tried pulling and tugging even tried chaining one end to the frame of my motor host and pumped the jack till it would not pump any more. I have sprayed WD40 down both ends let it soak and tried the host again. Beat on it with a hammer while in the host thought the vibration may help. NO LUCK. Should I just chain one end to a tree and the other end to the tractor and pull till it comes apart or breaks? Any ideas would be greatly appreciated.
Tom
Don-Wi
08-28-2005 19:48:19
 Re: Stuck PTO shaft ? in reply to TomWNC, 08-28-2005 13:03:48
We've always just chained or strapped the shaft between either 2 tractors or whatever. We haven't broke one yet, and some have been rusted for many years. We ussually use tow straps around the sheild, not on the joints, as it's ussually the sheild that's rusted.
Donovan from Wisconsin
Don-Wi
08-28-2005 19:48:15
Bus Driver
08-28-2005 17:33:34
Three things in combination-at the same time- will do the job. The pulling and hammering are OK. Add heat to those. Not too heavy on the hammmering- damage not desired. Away from the the u-joints, pour on the heat.
old
08-28-2005 13:07:57
Have you tried heat probably a lot of rust in it and if you can heat it up and then pour tranny fluid down in to it, you will probably get it loose
TomWNC
08-28-2005 13:27:19
 Re: Stuck PTO shaft ? in reply to old, 08-28-2005 13:07:57
I have not tried heat. It has a plastic guard/cover on it. How does that cover come off?
JMS/MN
08-28-2005 16:09:07
 Re: Stuck PTO shaft ? in reply to TomWNC, 08-28-2005 13:27:19
At the end of the tube, start of the bell-shaped structure are some holes or slots. Use a screwdriver to push in the metal or plastic that is in those slots. They hold on another piece that fits in a groove on the pto shaft. Break them? They come in various sizes- are available at farm stores and dealers.
old
08-28-2005 16:02:31
That can be a problem. Can you pull the end up so you can pour tranny fluid in? If so it does work better then WD 40 does. Another thing you can do if you can get close to it is hook it to a tractor pto and spin it a little but you may not be able to get that close.
TomWNC
08-28-2005 23:43:03
 Re: Stuck PTO shaft ? in reply to old, 08-28-2005 16:02:31
Can�t get that close. At this point I have the shaft off the mower. I will try the tranny fluid. I am going to try and get the plastic cover off so I can apply some heat.
