Tool Talk Discussion Forum
9nh running rough
john hendrix
08-22-2005 17:22:25
my 40? model 9n has a hole in tne governor onthe back where it has a little raised button looking piece, started mowing when the thing busted out of the governor. ran fine for about an hour, then started running rough, if i pull the choke about halfway out the tractor runs fair, but under a load it starts running rough,could this be from the governor.and can i interchange one from a 49 8n thanks john
BobOHIO
08-24-2005 19:42:46
 Re: 9nh running rough in reply to john hendrix, 08-22-2005 17:22:25
John-Sounds like it is starving for gas. My farmall would only run part choke and carb passages were plugged and needed a good carb cleaning and rebuild.
oldart
08-22-2005 20:54:52
the govener from an 8N will work on a 9N shuld have nothing with it running rough art
