Tool Talk Discussion Forum
Help Identifying Old Tool
BURT
08-22-2005 15:16:06
third party image
Can anyone help identify this old tool. It was found in the Livermore Valley, CA. I hope the picture comes through.
Thank you.
big jt
08-24-2005 09:43:52
 Re: Help Identifying Old Tool in reply to BURT, 08-22-2005 15:16:06
Got a couple sets of those myself. They work real nice for holding pipe when turning fittings on or off. Just find a collar that will slide all the way down the handle. Adjust the thumb screw so the tip of the handles are even and drive the collar down the handle. Jaws will clamp tighter than haities.
hth
jt
BURT
08-24-2005 12:09:34
 Re: Help Identifying Old Tool in reply to big jt, 08-24-2005 09:43:52
Thank you for the info. We tried it on a pipe and were suprised at how well it worked.
BURT
08-22-2005 15:19:00
third party image
The picture didn't show up in the first message. If ti doesn't show up in this message, it can be found in the "Help Identify" Gallery.
Thank you.
John Garner
08-22-2005 16:22:44
 Pipe tong in reply to BURT, 08-22-2005 15:19:00
Burt --
You've got a pair of "pipe tongs", which are generally considered to be an early-day pipe wrench. The screw is used to adjust the jaw opening to fit different pipe sizes.
For all practical purposes they are used just as you would use a heavy-duty Channellock or Knipex water pump pliers; once they get a firm bite on the pipe they'll hang on as long as you keep pressure on the one handle . . . you shouldn't need to keep squeezing the handles together.
John
BURT
08-22-2005 16:57:19
 Re: Pipe tong in reply to John Garner, 08-22-2005 16:22:44
Thank you for the info. They were found underneath a house that was being remodeled.
Thank you again,
Steven
