Tool Talk Discussion Forum
Sprayer
houndog
08-18-2005 19:19:51
I am looking to build a sprayer that i can haul in the back of my john deere gator. I know such units can be bought already put together, but a bit more than i want to spend. all i need it for is to spray fence rows. currently using 3 gallon backpack sprayer. I am thinking that i could use a 20 gallon tank, or something like that, and use a tank of compressed air to power it. my questions are, how big a water tank compared to my air tank.,what preasure should i need, i would use a regulator on the air hose. All ideas appreciated! Thanks mike
Vinnie
08-19-2005 09:31:48
 Re: Sprayer in reply to houndog, 08-18-2005 19:19:51
I have made a couple of these using a 12vdc sprayer pump ($60-100) and any plastic container or jug depending on the amount of solution I want to spray. If I only want to spray Round-Up I drop the suction line in a 2.5 gal jug and spot spray around the yard. If I need to spray liquid seven, I might mix up a 30 gal barrel of it and drop in the suction line and go. Old stainless fire extinguishers make great 2.5 gal sprayers. Just replace the 18 inch nozzle with a 4 foot hose and a wand, fill it up to the line and pressurize with your compressor through the schrader valve until the needle is in the green area on the gauge. When the solution is gone, there is usually a little air left. Good Luck.
-Vinnie
Slowpoke
08-19-2005 11:08:23
 Re: Sprayer in reply to Vinnie, 08-19-2005 09:31:48
Vinnie, how did you replace the original hose with a longer one? I want to set up one of those extinguishers as a shower with a long hose and shower head for use where there's no power & water out in the sticks. I can pressurize it with a 12 volt compressor. The threads on the extinguisher outlet are a special size, so what did you do to change to a longer hose?
Vinnie
08-22-2005 08:42:49
 Re: Sprayer in reply to Slowpoke, 08-19-2005 11:08:23
Slowpoke:
The original hose/nozzle has a factory, machine clamped fitting to connect it to the "head" of the extinguisher. I typically use a pair of wire cutters to cut into the hose where the band-clamp is located. You can nip and peel the band-clamp from around the hose at this fitting. When you have removed the clamp, you can cut away the hose. This leaves you with a nice barbed 3/8 inch connection to put your new, longer hose on using a regular screw clamp. The old "wide mouth" tanks seem hard to find, but they are great for filling up with solution. The smaller ones need a funnel to avoid spillage. Good luck.
-Vinnie
Coloken
08-19-2005 07:33:48
I think you got it pretty well figured. Any old water well tank, but look out for rust. Use a filter on the output. I would say like a 20 gal tank but only 5 to 8 gal in it. that way the air should be enough, pumped up at the ahop to last the whole thing. Even a 40 gal with 10 gal in it would weigh about--- less that another person?
Kennyp
Mattlt
08-19-2005 05:59:37
I've thought about doing this as well. What you might want to find is an old well pressure tank. Just fill it up with your spray solution, pump it up to whatever pressure works, and off you go. Ask your local well driller, he may have one laying around that he'll part with.
Another thought is to use a 12v air compressor to fill your air tank. Available very cheap just about anywhere. My Polaris 6x6 has 12v available in the rear, I'd imagine your Gator would too. You may need to fill your air several times for each fill of spray solution.
I don't believe pressurizing an off-the-shelf sprayer tank would work. Don't most of them have a ventilated lid? Could be wrong on that... Either way, I doubt they're made to handle much pressure.
Also, remember water weighs over 8# per gallon. Don't get too carried away with the size of the tank. 20 gallons wouldn't be a problem, 55 might be.
