Tool Talk Discussion Forum
OT Bubbles for levels
Dieselrider
08-18-2005 16:39:11
All levels have these little tubes with fluid and an air bubble inside and a couple lines so you can tell where level is right? Who makes the little bubble totin vials for levels? I have a littl project and would like to obtain a few (dozen or so) but, I have not found a source. I could scrounge around and find old broken or bent levels I suppose but would prefer to use all one size shape etc. If anyone knows of a source I would appreciate the help. Thanks.
Dell (WA)
08-19-2005 06:09:54
 Re: OT Bubbles for levels in reply to Dieselrider, 08-18-2005 16:39:11
dieselrider..... ...I used to make special test fixtures with bubble levels that I'd buy from a "surveying instrument" repair shop in Seattle. He'd order 'em for me, but he always had an assortment that I'd brouse thru. Tubular vials he called them. Ennywhere from 1/8" dia and 3/4" long to 1/4" dia and 2" long. He used special plaster glue, but I'd use epoxy. Different fluids, like glycerin for slow reaction; alcohol for fast reaction..... ....Dell
Tim in OR
08-18-2005 21:03:46
I have some hidden somewhere in my shop. They are the vials like used in levels, packed in sawdust in a box. I will have to get to the shop this weekend. Wont hurt your pocket too much either. :-)
send me an E-mail and we can talk.
Tim in OR
Slowpoke
08-18-2005 21:54:08
 Re: OT Bubbles for levels in reply to Tim in OR, 08-18-2005 21:03:46
Those hidden level vials wouldn't happen to be MD series 600 would they? Also known as #27003, kit 007. I'm trying to restore a 78" MD level. It was used in masonary work so the vial covers are very deteriorated and the bubbles can't be seen.
Davis In SC
08-18-2005 19:28:15
Some of the tool sellers, such as Travers, MSC, J&L, etc. sell the round leveling bubbles that stick on.....
old
08-18-2005 19:00:43
Go to an RV place and buy the levels they use on travel trailors. most are in plastic so it should be easy to use them for yopur what ever it is
MarkB_MI
08-18-2005 18:32:04
I'm sure there's a source for the vials, but a simpler and cheaper way might be to buy a bunch of plastic string levels. Just grind off the string hooks and you're good to go. Any hardware store will stock them and they're only a couple bucks apiece.
