Tool Talk Discussion Forum
Welder output.
Carol Martin
08-18-2005 15:43:47
Hi: I have a miller AEAD portable welder. And am wondering if anyone can tell me Why they have a 110V 100HZ 9Amp output. it has the regular 110 60HZ outlet and I cannot figure any good use for this output.. (must be a reason for it)
Carol
buickanddeere
08-23-2005 20:57:23
 Re: Welder output. in reply to Carol Martin, 08-18-2005 15:43:47
An AC universal motor. That is a serie smotor with brushes such as those in vacuum cleaners, routers, skill saws, grinders, sewing machines, electric drills etc. They don't care if they are fed Dc or 100Hz AC as long as the voltage is correct. The extra impedance at 100Hz can almost with univeral motors. An electronic variable speed trigger can be messed up on DC or off frequency AC.
ScottP
08-20-2005 18:34:19
Hello Carol
Barry is correct. The 100 hertz outlet is for your helper to use an angle grinder or for a light while you are welding. Most angle grinders will run at 100 htz. with out a problem. Scott
Richard H.
08-19-2005 08:06:04
This is only a guess Carol, but I do remember several years ago 20? I was working at a new Japaneeeeese factory and the Japaneeeees were installing thier own machines. As an electrician my apprentice and I were going around installing special equipment so they could use their power tools. My apprentice asked, " Why are we doing this, They are using the same Skill, B&D, Milwaukee tools we are!" I told him that when they make all those tools over there it sure is nice of them to make them 120v 60hz for us. You could probably open it up and disable the frequency drive in it and wire it normal or should I say American. Richard
Carol Martin
08-19-2005 12:45:00
 Re: Welder output. in reply to Richard H., 08-19-2005 08:06:04
HI Richard: I dont think this has any connection to foreign current needs. They run at 50 HZ This is 100 HZ. The machine also has the regular 110 60HZ output. It just has this one outlet on the front that is 100HZ at 110. Just cannot figure out what it was intended for.
Carol
Richard H.
08-19-2005 15:52:50
 Re: Welder output. in reply to Carol Martin, 08-19-2005 12:45:00
Ok how about this, I googled it and believe it may be for a stud welder to be connected to. RH
T_Bone
08-19-2005 22:41:20
 Re: Welder output. in reply to Richard H., 08-19-2005 15:52:50
Hi Carrol,
I'm not fimular with a AEAD machine but I think that outlet would be for where the Mig head feed remote contact plugs in. I believe the feed head drive motor reuires 100hz. Is it a CV machine or just a CC machine or a CV/CC machine?
I'm not sure tho so do some research on it.
T_Bone
barryinmn
08-20-2005 10:53:35
 Re: Welder output. in reply to T_Bone, 08-19-2005 22:41:20
I have a gas '70 AEAD as well, the single plug 110V can be used at 3000 welding RPM to run a grinder etc. Mine has a frankenstein switch for the 5KW 110/230 60 AC generator function & motor RPM is reduced to 1800.
Most of the hand tools will run at different frequencies but less efficiently - may have lower torque or heat up quicker.
