I have plumbed several shops with PVC pipe and never had problem--use an air hose as a flexible link to reduce vibration: also use electrical conduit clamps on pvc pipe. One of my best suggestions for wiring a shop is to wire a rotary one hour timer ahead of the compresser. Then if a leak occurs the longest time the motor will run would be one hour. good luck! a compressor big enough for my garage. : : : now i want to run air lines. ive heard both good and bad things about pvc and galvinized. : : : 1) If i go with pvc i need some sort of cushion between compressor and lines correct? : : : 2) if i go with galv. do I need to use a "cushion"? : : : 3) What size line should I use : : : My compressor is a 5.5 hp 30 gal craftsman. : : : thanks guys : : : jake from il
: : Use a flexable connection no matter what kind of hard line you use. A piece of air hose will work fine. Always turn your compressor off when not in use,a line, hose, coupler, ect. could blow anytime, whatever it's made of and burn up your compressor, or your shop. : Definatly use a flex connector, I would not reconmend galv. pipe : its does oxidize on the inside. I have plumb our shop with : sweated copper with has worked well for about 15 years. : At home I have used regular air hose and run it all over : the place. At Cosco it was really cheap, $15.00 : for a 100 feet. It was easy and works well.
