Tool Talk Discussion Forum
JB Weld Heat Exchagner
jb ct
08-18-2005 04:37:04
Our oil furnace heat exchanger(cast iron) has a hairline crack in it.
Runs horizontal for an inch or so seeps water out. Was wondering if anyone had any luck with JB Welding an oil furnace. Would you drill the ends of the cracks to stop the propagation? Thought about trying to braze it with nickel as the filler but I'm not so confident in my brazing ability in the space I have to work.
Thanks for any thoughts.
T_Bone
08-19-2005 22:06:20
 Re: JB Weld Heat Exchagner in reply to jb ct, 08-18-2005 04:37:04
Hi JB,
It's a very bad idea to try and repair a heat exchanger crack. How the crack got there is from the exchanger expanding and contracting so many times that the metal is now fatiqued. The next time it carcks it will usually be larger thus spuing more hot water.
A person walking by just as rupture happens will have scars the rest of there life from 180� water.
Replace heat exchangers, don't repair.
T_Bone
jb ct
08-22-2005 06:17:38
 Re: JB Weld Heat Exchagner in reply to T_Bone, 08-19-2005 22:06:20
Not going to mess with it. Turns out the manufacturer has a recall for the heat exchanger a casting issue. Will find out in a few days if its covered thanks for the replies.
Bill Hires
08-18-2005 15:31:49
I use Permatex Hi-Heat Metal Repair Compound to repair cracked exhaust manifolds, it is "OK" to 2,000 degrees Fahrenheit. A tube costs $ 7.34 at our Auto Parts House.
Jon Hagen
08-18-2005 14:49:34
Not likley to work. JB weld turns to a liquid and drips off at under 400 degrees.
Slowpoke
08-18-2005 12:18:50
I used it on a Ford 9N cracked block. About 4-5" long, it stopped the leak. But there's little pressure in the block. If you can get to the inside of the crack the JB Weld should work. Even if you put it on the outside and it leaks you're only out $3-$4. Clean the area well and let it set up for a few days before using. Or check industrial suppliers or a marine supply for a water proof epoxy.
Mike M
08-18-2005 09:47:57
Might be a good idea to replace that furnace. The carbon monoxide may get to you !
