Tool Talk Discussion Forum
Highest RPM tractor
Glenn FitzGeral
08-17-2005 17:55:43
Just curious...What's the highest factory engine RPM you know of? Thanks, Glenn F.
buickanddeere
08-18-2005 23:24:37
 Re: Highest RPM tractor in reply to Glenn FitzGerald, 08-17-2005 17:55:43
53 Series Detroit with four valve heads and the updated springs were rated for 2800 under load. Fast idle was 2950 or something in that area. Some little Diesels diesels on generators ran at 3600rpm.E.G. Onan, Yanmar etc.
big fred
08-18-2005 07:16:47
Not exactly production, but IH built an experimental tractor with a turbine engine. I would imagine that would have turned somewhere in the range of 10-30,000 RPM.
Bob
08-18-2005 07:50:30
 Re: Highest RPM tractor in reply to big fred, 08-18-2005 07:16:47
Supposedly 57,000!
Illinois Boy
08-18-2005 11:08:18
 Re: Highest RPM tractor in reply to Bob, 08-18-2005 07:50:30
Bob - That was GREAT!!
I love "The Oliver of Tomorrow"...
Frank P
08-18-2005 06:28:45
Probably my Super M when the hired boy came down the long hill to the farm with 2 loaded hay wagons behind it. Must have hit about 6000 rpm before the 2 rods came through the side of the block and broke the crank.
Ghostrider
08-18-2005 05:22:13
I had a friend with a 7080 Allis that wound out to 2800-3000 rpm with the six cylinder. He blamed the high speed as a factor in the poor reliability of his tractor. I think they had a recommended service interval for replacing rod bolts like the Cat V8 engines.
730LP
08-17-2005 21:35:30
I have a LEHR Big Boy that came from the factor with a Chylser engine. RPM's are set with gov. at 2950 but could turn almost twice that.
Loren
08-17-2005 20:04:41
Wouldn't that be one of the numerous models brought out with the Detroit "Jimmy" diesel?
Bob
08-17-2005 20:24:15
 Re: Highest RPM tractor in reply to Loren, 08-17-2005 20:04:41
The "Jimmy" diesels are 2-stroke cycle engines, so they have twice the exhaust pulses at a given RPM than a 4-cycle engine at the same speed, so based on the exhaust sound, they sound like they are running twice as fast as they ACTUALLY are.
Can't even use my name
08-17-2005 18:56:21
Not sure but our MF 1800 has a V-8 Cat that hits 3000 rpm's without a load. I would think any other V-8 powered tractor would be in that range too. Of course there may be a gasser that revs higher.
