Tool Talk Discussion Forum
Clutch
Bernie in MA
08-16-2005 14:34:39
Anybody ever try to rig an air cylinder on a clutch. I've got 4 tractors and 3 trucks with standard trannys and my left knee isn't getting any better with age. I've already had the right one replaced and just as soon not go thru that again. TIA
JMS/MN
08-20-2005 10:16:32
 Re: Clutch in reply to Bernie in MA, 08-16-2005 14:34:39
Very possible to do that or use mechanical linkages. Search for 'Agrability Project'. It's at nationwide universities, not just in the midwest. For a contact, shoot an email to [email protected].
Ghostrider
08-18-2005 05:19:38
I have heard that some county extension offices have programs for this type of work. They help design and install controls for tractors and such. Might be worth asking around.
T_Bone
08-17-2005 11:22:09
Hi Bernie,
I would use a "live" hydraulic cyl on the tractors as you already have hyd power available. I was thinking the pedal would "only" operate the spool valve. The cyl would do all the work. Use a small resevior (1-1/2" x 6" long pipe with end caps), supply oil check valve, too supply a couple clutch strokes if the engine was off.
On the trucks if you have air, then use a air cyl for the same reason.
You then would only push against the pedal return spring and the resistance of the spool valve, a very easy push.
T_Bone
Slowpoke
08-17-2005 09:49:45
I had a 1965 IHC Travelall that had a hydraulic clutch assist. Something like a small master cylinder but I don't remember how it was hooked up. I have the book somewhere. Scout & Travelall enthusiasts have a club. Look for it on the web. Maybe someone can tell you how to adapt a clutch cylinder for your use.
Dusty MI
08-17-2005 17:23:18
 Re: Clutch in reply to Slowpoke, 08-17-2005 09:49:45
We had a Ford F-150 pick-up, that had a master slave hydraulic clutch, no assist, just hydraulic line instead of linkage.
Dusty
Slowpoke
08-18-2005 11:50:41
 Re: Clutch in reply to Dusty MI, 08-17-2005 17:23:18
Yes, I think mine was the same as your Ford, with no assist. That's why I replaced the 4 speed with an automatic 3 speed after a few years of pushing the clutch pedal in traffic.
Jimmy King
08-17-2005 04:00:22
Bernie, round balers are no friend to left knees are they
Bob
08-16-2005 20:14:17
Certain IH tractors had a hydraulic assisted clutch.
They were like a litle power steering cylinder, with it's own valve, so there is proportional assist throughout the whole cycle, as the clutch was depressed.
Also, I have wondered if a dash-mounted vacuum brake booster could be used to assist with operation of the clutch?
RustyFarmall
08-16-2005 18:27:10
I hear you on the knees, mine are not that bad yet, but they are headed that way. I have been to several antique tractor shows where I noticed a few tractors rigged up with a hand operated clutch, some were a bit crude, others looked very professional, but they all worked. Maybe someone has a set of plans for building one?
oldart
08-16-2005 20:33:17
 Re: Clutch in reply to RustyFarmall, 08-16-2005 18:27:10
look into handycap veichels the have a hand operated brake control why not a clutch . i know you will get it done somehow. art
