Tool Talk Discussion Forum
lincon welders onan engins
william mcc
08-15-2005 22:15:44
my lincon ranger 8 will not run with out having it at full choke its an onan engin and under warenty but the closest dealer is 80+ miles away any ideas fule filter is clean and only got 16 hours on it new fule ??im at a loss any help
Kmiller
08-20-2005 19:52:36
 Re: lincon welders onan engins in reply to william mcc, 08-15-2005 22:15:44
Fawteen is right, if it sat without running for more than a month or two, the carb is probably gummed up. The gas these days is very corrosive and plugs up those tiny idle jets pretty easily. Take the carb apart and push some fine wire through the idle jet and that will fix it. Clean up the whole carb while you're there, you'll probably find some corrosion and some fine powdery stuff in the bowl too.
Fawteen
08-16-2005 09:31:23
Most likely culprit is crud in the carb partially blocking a fuel passage. Take it off, take it apart, clean it thoroughly and blow it out.
