Tool Talk Discussion Forum
What welder to buy? Strange circumstances.
LeMaverick
08-13-2005 12:40:11
What welder would you buy in the following situation:
We live full-time in a fifth-wheel travel trailer pulled by a faithful old Dodge Cummins � ton. Space and weight are a consideration but we have some leeway.
I am an old �stick� welder of modest talent but hundreds of hours of experience on a Lincoln 225 �buzz box� and a Miller gasoline powered machine; however, there isn�t room for the gas and we usually don�t have available 220 VAC (and carry only a modest generator).
Am I am going to have to �bite the bullet� and go to wire-feed � for space, weight and power considerations?
I have only limited experience and exposure to those machines and need advice. I would like the machine to have the capability to weld a truck frame, spring shackle, etc and to be adequate to build a flatbed for the pickup. And, of course, I would like to keep as much as possible of our limited supply of cash.
So, what�s your thought?
LeMaverick
08-16-2005 19:42:55
 Thank You in reply to LeMaverick, 08-13-2005 12:40:11
Thanks everyone for your input. I'll be busy checking and deciding.
Kmiller
08-15-2005 18:26:40
 Re: What welder to buy? Strange circumstances. in reply to LeMaverick, 08-13-2005 12:40:11
Do you have a generator for your trailer? I have a 5500w generator and can run my Lincoln welder at 90 amps on it just fine. It will sort of do 120 amps but you can tell it's starting to sag so it's probably not good for either one. Maybe you can use the generator for the trailer and the welder.
If you're doing fairly light welding, don't be afraid of the little mig welders, they are very easy to use, easier than a stick welder. The cheap ones don't feed the wire reliably so it's hard to make a good weld with them, but if it's feeding properly it's a no-brainer to use one.
T_Bone
08-15-2005 12:00:40
Hi LeMaverick,
Well you have limted choices.
Buy a machine and generator combo
Buy a machine, rent the genset
Rent both machine and genset when needed. This would be the most cost effective.
I would not buy a Mig machine for your usage. That would require a 230v, 200A machine. Large and heavy. Any less than 200a then cold lap is a problem.
A 115v invertor machine with using 3/32" electrodes works well. This still requires a genset with 115v 30a circuit and 230v machines use 25a input, the better deal. The typical machine is small and only weighs 50lbs or so.
T_Bone
NC Wayne
08-13-2005 21:38:48
Stop by a welding supply house and take a look at all the different machines out there nowdays. I'm not gonna name any specific brands as being good or better than any others because except for the occasional "test bead" I haven't used any of them for any amount of time. There are inverter machines that will run off pretty much whatever voltage you plug them into that are as small as a briefcase and capable of 300 amps or more. Recently I saw one that is about the size of a medium sized cooler that runs off a small two stroke motor. I didn't see who made it or what it's specs were but the guy using it worked for a fencing company and said they routinely run it all day repairing/adding onto existing fences where other means aren't available. If your already experienced at stick welding and your not specifically looking for something else it'd pay you to take the time to check these new machines out.
ScottP
08-13-2005 19:34:35
Check out the Miller welder that is dual voltage.
It will do 120 or 220 volts. If i remember right they are 180 amps and around $1000.00.
Scott
JL Sargent
08-13-2005 18:34:48
You dont indicate what you might be welding. If light gage stuff then go with one of the good brand 120v flux core wire welders. I have two of the Lincolns and really enjoy them for their portability and easy to find voltage. I wouldnt recommend that one for trailer building or repair but for light gage sheeting and angle its good.
Stan Lewis
08-13-2005 16:06:14
Hi, LeMaverick
A company named Zena makes a welder that is basically an alternator that mounts under the hood of your vehicle and is powered by a vee belt. For about $500 you get a 150amp unit which has a 100% duty cycle. Zena sells these regularly on eBay as a promotional method. There was one for sale yesterday when I looked at welders there. They throw in some stuff if you pay the Buy It Now price which, if I remember correctly, is scarcely above the Reserve Price.
People on this forum have complained that the price was too high because you could buy the components for much less and make it yourself, if you knew how. It seems to me that you could say that about anything. The Zena welder really has my interest; I'm mainly afraid that I'd never get around to installing it.
All the best, Stan
