Tool Talk Discussion Forum
Trying to understand Standard system.
Jay87T
08-13-2005 08:13:40
Well, Im trying to get the messurement of my electric motor shaft for a new pully I need to buy, the shaft is more than 1 inches in diameter, now I dont know if its 1 1/8 , 1 3/8, 1 3/16 , 1 7/16. being from Canada and all, Im not really educated on the Standard system of messurements, everything i use is metric, can someone please simplify this system for me real quick, I tryed looking online but cant find much. Would be much easier if they just said. 1.25 or something like that.
Thanks.
CNKS
08-13-2005 17:37:49
 Re: Trying to understand Standard system. in reply to Jay87T, 08-13-2005 08:13:40
25.4 mm/inch, 1.125=28.575 mm, etc. The US should have converted to metric years ago. We aare about the only ones left using the English system. Metric system is much simpler, just takes a while to learn it.
buickanddeere
08-13-2005 12:41:09
You must be aged 40 or less? That liberal s.o.b. Trudeau rammed the metric system into being via and "Order In Council" . Instead of allowing public scrutiny through Parliament.
fepo
08-15-2005 07:32:58
 Re: Trying to understand Standard system. in reply to buickanddeere, 08-13-2005 12:41:09
while Canada should have waited for the US to change as well, I still think the metric system is superior to the standard system, which is completely outdated and based on an archaic measurment method that no longer makes common sense.
Stickler
08-14-2005 15:26:07
Trudeau was the one that got us french on our cereal boxes too! At a cost of untold billions. GRRR!!!!
And put the armed forces all in green bus driver suits.
And got us a constitution with no rights at all.
Davis In SC
08-13-2005 08:52:07
Get a dimension in Millimeters, & multiply it by .03937 .. That will give you the size in inches, in a decimal format.
1.125 is 1 1/8
1.1875 is 1 3/16
1.250 is 1 1/4
1.375 is 1 3/8 Etc..... .....
Jay87T
08-13-2005 08:58:26
 Re: Trying to understand Standard system. in reply to Davis In SC, 08-13-2005 08:52:07
perfect thats exactly what I was looking for, Thanks Davis, I see its 1 1/8.
T_Bone
08-13-2005 09:24:20
 Re: Trying to understand Standard system. in reply to Jay87T, 08-13-2005 08:58:26
Hi Jay,
Download a program called Convert IT, a shareware program. Really a neat program with big functions that I've had for the past 8yrs or so.
Works on any puter as it's a stand alone program, doesn't need the OS to function, so I've used it from Win95 to XP.
T_Bone
