Tool Talk Discussion Forum
Carburator bushing removal tool
AWB
08-11-2005 18:49:07
I need a tool to remove carburator bushings and packing. What is the name of the tool and where can I purchase one?
riverbend
08-14-2005 19:23:16
 Re: Carburator bushing removal tool in reply to AWB, 08-11-2005 18:49:07
If the bushing is in a blind hole, you can thread the inside of the bushing and pull it out with a bolt.
AWB
08-14-2005 19:43:02
 Re: Carburator bushing removal tool in reply to riverbend, 08-14-2005 19:23:16
Thank you for the information regarding the bushing removal. It is greatly appreciated.
Slowpoke
08-11-2005 21:41:38
Do you mean the throttle bushings? Once the shaft is removed, use a round head screw that will fit in the bushing. The head needs to be slightly smaller than the od of the bushing. Insert the screw into the bushing from inside. Work through the opposite bushing hole, using any shaft to reach the screw head and tap it with light hammer blows. It should force the bushing out the exterior of the carb. Be sure to place the bushing to be removed over a backup plate with a suitable size hole in it so you don't break the carb casting.
